Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-21-2020, 02:00 PM
cqd cqd is offline
Default Re: General Lag issues in Pro Tools Ultimate - Windows 10
I found trying to sort out msi interupts made this a bit better..
I can't remember how to do it now, but google it..it helped with lag in my machine..
Old 12-14-2020, 10:09 PM
Sound Editing MunKee Sound Editing MunKee is offline
I'm having lag issues too with my windows and Mac systems running PT ultimate 2020.11 and 2020.9 respectively. With the editing lag being described here are you using video in the session? My systems are very fast and responsive without video but as soon as you use video things become sluggish. I started a thread here about that:
http://duc.avid.com/showthread.php?t=413077
Old 12-15-2020, 12:14 AM
Emi's Avatar
Emi Emi is offline
I’m on Mac so I don’t know much about window but, did you install some new plug-in ? Also, did you trash preferences?
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 12-15-2020, 10:10 AM
Back to the OP, some things to try:
1-update graphics drivers from the nVidia site(in case you got your updates from HP or the card maker)
2-disconnect the 2 USB drives(wondering if they are bogging down just by being connected)
3-Try the Core Affinity trick(already well-documented on the DUC)
4-(really grasping at straws here), pull 1 stick of RAM and test, then swap out for the other stick(wondering if 1 stick is maybe defective)
I agree that you should have a monster of a computer(and I am considering a similar setup but the the Designaire mobo for TB3), so, fingers crossed for a solution
Old 12-15-2020, 11:41 PM
sw rec sw rec is offline
Long shot, because newer motherboards PROBABLY have finally eliminated this, but go into bios and see if there’s a floppy drive enabled. Even if you don’t have a floppy drive, or even a port for a floppy drive, it might still be in your bios. If it is, disable it. Worth a look, anyway.
  #16
Old 06-21-2024, 07:43 AM
mussor mussor is offline
Have you found some solution, anyone? I have similar MOBO: Z390 Ultra with i9-9900 and facing the same issue. I've found out that disabling ethernet adapter at startup does speed it up. But it gets slower after some time anyway...
Pro Tools Ultimate iLok asset issues - need urgent help nhaudio Licensing & Accounts 4 09-10-2019 08:00 PM
Pro Tools LE 8.0.5, M Box 2, Win 7 Ultimate, Cracks/pops/audio issues AliGlenUig Windows 11 12-17-2015 08:08 AM
Windows XP and Pro Tools Setup and General Troubleshooting DigiTechSupt Pro Tools TDM Systems (Win) 1 05-11-2010 02:32 PM
General Troubleshooting - Pro Tools LE on Windows DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-11-2010 02:30 PM
Pro Tools & GigaStudio: clocking issues / general advice? maxx Pro Tools TDM Systems (Mac) 6 09-05-2001 11:31 AM
