Old 01-12-2016, 08:32 AM
protoolsnewbie protoolsnewbie is offline
Default Automation shortcut doesn't work
hi!
i need help with the automation shortcut "write to all enabled" which is "cmd + option+/" on a mac.
i want to use this for write an automation on a selection. the plug in automation is enabled and so on...
the funny thing is: if i use it with the window function and click on this. it works!
but with the shortcut which is shown behind the window option it doesn't work..
what's wrong?
I'm using a protools 10 HD with a mac pro (osx 10.6.8)
Thanks a lot!
Old 01-12-2016, 08:35 AM
Drew Mazurek's Avatar
Default Re: Automation shortcut doesn't work
Originally Posted by protoolsnewbie View Post
hi!
what's wrong?
Thanks a lot!
This is a known issue with non english keyboards. Avid is aware.
www.drewmazurek.com
Old 01-12-2016, 08:38 AM
oh!
thanks for the quick reply!
I will change the keyboard....
Old 01-12-2016, 08:50 AM
or is there another workflow....?
Old 01-12-2016, 09:37 AM
joachim's Avatar
joachim joachim is offline
Preview Automation !
Enable Preview , Track to latch(or touch)
make a selection , playback (in this order !!!)
tweak anything
when happy (still playing back with the same selection) : write-to-all (right-click on the return to zero button) or in the automation window : manual write - automation to selection.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-12-2016, 09:43 AM
joachim's Avatar
"cmd + option+/"
The "/" on the numeric keypad ?
12.4 - shortcut for opening midi editor doesn't work BigBadBill Pro Tools 12 13 01-09-2018 06:21 PM
Backwards nudge shortcut key doesn't work....? Marello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-29-2006 07:27 AM
quantize shortcut doesn't work -- bug? c-post MIDI 1 07-10-2004 10:15 PM
toggle view keyboard shortcut doesn't work Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2003 08:54 AM
Automation breakpoint shortcut doesn't work CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-03-2001 12:23 AM
