Old 04-10-2010, 10:29 PM
dkbarnwell dkbarnwell is offline
Default Reverse Selection???
Hello All,
I am trying to "reverse" an audio track and having some trouble. I did this trick several years (or upgrades) ago and can't seem to make the magic happen again. I am running LE7.4 and I guess I am suppose to select the track and choose "reverse" from the audio suite menu and apply the process to the track. I have selected to overwrite the file and I can see the track, well change but it certainly isn't backwards as I would expect. Oh, yes, I tried the same steps using "invert" from the audio suite menu as well...same result...
Even stranger, I can hit the "preview" tab while in "reverse"and hear the track backwards but can't make it happen when I hit process.
Can anybody get me going in the right direction on this?
Thanks in advance,
Derek
Old 04-10-2010, 11:55 PM
tlennon tlennon is offline
Default Re: Reverse Selection???
Maybe the track is too long for the process which I would expect the audio goes off line for quite a while if it is a 5 min track. Try and break it up. Copy to another track and cursor to the bar 9 of the duplicate track and press Ctrl-E then select from bar 1 - 8 and see if you can reverse the 8 bars. The audio suite is the way to go so you aren't doing anything wrong.
Terrence Lennon
Ivory Key Productions
Old 04-11-2010, 12:18 AM
Thanks TLennon!
I figured out what I was doing wrong... I was in fact doing all the steps correctly but I didn't notice was the "reversed" track was showing up in the play list instead of simply replacing the selected track as I was expecting. Once I noticed that, it was just a matter deleting the source track and dragging the "reversed" track out of the play list and into the track in the edit screen.
Works like a charm! Thanks again for your input,
Derek
Old 04-11-2010, 08:38 AM
When you call up an AudioSuite plugin, there is a "button" on the plugin that says USE IN PLAYLIST. If that is lit, the new audio gets placed for you(saving a step)
Old 04-11-2010, 11:27 AM
Glad you got it worked out DK and thanks for that update Albee. I forgot all about that button.
Terrence Lennon
Edit Selection Follows Clip List Selection not working Sjoberg Pro Tools 10 3 12-04-2020 12:38 PM
Playing back part of a selection without affecting timeline/selection jschmidtiii macOS 2 05-11-2013 01:05 PM
Edit Selection Follows Region List Selection->NOT! alteregg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-14-2006 03:40 PM
Reverse selection end move command (R.S.E.M.C.)? Mick F. Cantarella Tips & Tricks 3 05-09-2003 10:41 AM
Reverse selection end move command (R.S.E.M.C.)? Mick F. Cantarella Pro Tools TDM Systems (Mac) 2 05-04-2003 11:15 AM
