Old 11-16-2009, 04:45 AM
gbross gbross is offline
Default LE's Bounce to disk vs. Reaper Render to disk
Since I'm currently dead in the water with no Pro Tools LE- I have a new Windows 7 64 bit machine... I've been using Reaper to get a few recording projects out the door.
Why is the render to disk so much faster in Reaper? A 2 minute song takes about 30 seconds to bounce. Pro Tools bounce to disk takes the entire duration of the song.
What gives?
Old 11-16-2009, 05:02 AM
Jenk2k Jenk2k is offline
Default Re: LE's Bounce to disk vs. Reaper Render to disk
im going to respond before someone else says something sarcastic. basically, pro tools has never had a render function that was faster than real time (1x.) CD burning software and many other DAW's out there have written their algorithms to do so. It's just not something digi has done for the users. No one knows if they will, but it's been made awful clear that this is extremely important to users.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 11-16-2009, 05:08 AM
jmitchell1532 jmitchell1532 is offline
I always figured PT has to take the entire duration of the song to BTD because of the RTAS platform; that everything had to play out normally or else there would be pops and errors and such.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 11-16-2009, 07:02 AM
kbruff kbruff is offline
What gives?
Not just bounce to disk, but after the bounce you can directly import the results of the files that were bounced back into your current session, which makes verification and comparison a breeze!
Old 11-16-2009, 07:11 AM
sunburst79 sunburst79 is offline
One reason...From what I understand HD is prevented from doing because of hardware limitations-So LE can't do it either even though its not bound by the same limitations. Other reason...PT was designed for studio use. When it was designed most studios were still using a lot outboard gear. You can't render faster than real time through outboard gear.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-16-2009, 08:16 AM
That is why many daws have both options: real time and non real time.
Old 11-16-2009, 02:29 PM
slickrick slickrick is offline
It's always been real time because of instantiation of hardware inserts.
Old 11-16-2009, 04:49 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Originally Posted by Jenk2k View Post
..., pro tools has never had a render function that was faster than real time...
Actually it did back before RTAS. In practice it isn't that big of a deal.
Just assign the mix to a buss, route the audio back around into a track and record each section as you listen and tweak. Then simply consolidate the audio in that track and there's your rendered audio. This has the added advantage of being able to record into different playlists and then comp your mixes.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 09:07 AM
no render to disk? :( messenger Pro Tools M-Powered (Mac) 12 08-08-2006 01:28 AM
Bounce To Disk quick render Haniel Trisna Pro Tools TDM Systems (Mac) 17 10-15-2003 08:52 PM
Bounce to Disk vs. Render? Rammelt Pro Tools TDM Systems (Win) 1 12-17-2002 12:54 AM
