Every time I try to close one session PT will crash. Did a save copy in but new session does the same. Deleted pref's etc with no luck. This is on my HD system. What can I do?
Have you tried creating a new session and using "import session data" to import all the tracks? SB
Now did try this and tracks are all over the place at wrong positions + the new session crashes pro tools when closing exactly the same
![]() Quote:
Most likely cause is are old friend "the plugin" ![]() But which one? you'll have to start removing plugs from the folder till you find the one. Chris
will try that, just started going thru session file backup folder to see if any will close properly. plugs are all the same for several sessions from the album I'm working on tough.. no problems so far... damn this sucks... 2.5 hours lost and counting
![]() Quote:
triple check you have the latest versions.
had massey talkback on the session so I threw it out. now it opened and when I hit play all audio was "gone". I see the regions but no sound or meter action. still did not close properly.. will try to remove all plugs..
disabling all plugs did not help (inside session). session opens fine and plays fine. when closing I can hear action going on with the hard drive for several seconds and then kaboom "PT closed unexpectedly" other similar sessions with same plugs and tracks will take 0.5 seconds to close... will try to remove plugins from plugins folder to see if that helps
removed all plugs except stereo mixer and still the same problem so plugs are good. I guess audio file is bad... this is a tracking session with many unused and alternate playlists so removing unused is nothing I would love to do but as I have a copy I will try to remove and compact
removing unused audio and compacting did not help either. I am officially out of ideas!
PT 10.3.8 Crashes after closing session | drvibb | Pro Tools 10 | 2 | 03-20-2014 03:17 PM |
Crashes when (exiting/closing a session) | louieshowers | Windows | 38 | 11-16-2013 06:17 AM |
PT HD 7.4 crashes when closing a session | deardaddy | Post - Surround - Video | 10 | 05-21-2009 03:01 PM |
Crashes when closing session Pro tools 7.0 | Drive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-07-2006 01:34 AM |
pro tools app. crashes when closing session | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-27-2001 04:22 PM |
