Old 11-09-2007, 11:01 AM
BGee BGee is offline
Default Tab to transient doesn\'t work on elastic tracks
When a track has elastic audio enabled, tab to transient doesn't work properly. It will only tab to event markers. For example, if you have a few tracks of multitrack drums, you turn on elastic audio, switch to analysis view, delete all the markers, then try to tab to transient so you can scroll through and place them manually, tab to transient just tabs to the end of the region. If you manually place a few event markers, then tab to transient only tabs to those markers. What good is that?
Also, I'm getting really inconsistent results with multitrack drums. Again, if I delete all the automatically generated markers and group the tracks so I can place markers uniformly across all the drum tracks, then when I change the tempo more than a little, it is obvious that phase is not being preserved across the tracks. even though the event markers are uniform across all the grouped tracks. It sounds like all the tracks are warping a little differently.
And the weirdest thing I'm seeing is that when I delete all the analysis markers and just do a telescopic warp on say a 4 bar block of multitrack drums, then change the tempo substantially, everything goes completely awry and the audio seems to play randomly.
Something's not right.
Old 11-09-2007, 11:56 AM
ZEUSS ZEUSS is offline
Default Re: Tab to transient doesn\'t work on elastic tracks
I am experiencing the same thing. I don't see how this works on multitrack drums. Still a noob at this though. I tried it the same way you did. I deleted all the analysis markers and tried to make them myself but no tab2 trans. I could BD the section in no time.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 11-09-2007, 12:07 PM
SessionKat SessionKat is offline
Hi BGee - note that w/o any analysis event markers (as you deleted them all) the EA algorithm has no idea what to do. Analysis data is what is fed into the algo - w/o it, its no surprise that "everything goes completely awry and the audio seems to play randomly". also, it is intended for Tab-to-T to tab to event markers (only) when playlist is in analysis view.
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Elastic Audio won't work? try this 77pro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-03-2014 06:21 PM
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 10:35 AM
Elastic Audio and Tab to Transient broken rheomatic Pro Tools M-Powered (Mac) 0 08-24-2009 12:33 AM
Tab to transient on Elastic Audio tracks Steve MacMillan Pro Tools TDM Systems (Mac) 6 11-27-2007 11:36 PM
Grayed out tracks and tab to transient......help lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-21-2003 11:15 PM
