Old 04-16-2007, 10:20 AM
i hear dead people i hear dead people is offline
Default BUG? Unmount Disk Drive in Workspace - Does not work?
Using 7.2.1 cs2 -- I have my session closed and here's the problem I get -- When I try to unmount my WD "My Book" Drive via Workspace -- it will show that it has unmounted -- Then I switch to Finder and then Back to Pro Tools -- My drive has magically re-appeared???!!
Any thoughts on why this is??
-d
Old 04-16-2007, 10:35 AM
jre3132 jre3132 is offline
Default Re: BUG? Unmount Disk Drive in Workspace - Does not work?
what happens if you go ahead and unplug the drive without switching to the finder?
Old 04-16-2007, 02:39 PM
Andre Knecht Andre Knecht is offline
You’ll put your work at risk — that’s what happens. Don’t do it!
In fact, do not plug and/or unplug FireWire drives while they and the system are on. Ignore marketing claims, and do not treat FireWire as being hot-pluggable. You may have gotten way with it but it will bite you, sooner or later.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 04-17-2007, 07:24 PM
Guy Randle Guy Randle is offline
Whenver this happens to me I discover that I have another app running that is seeing the drive....like Jam or Quicktime. The workspace window will only unmount drives from the finder if PT is the only thing running.
I haven't had the fw problems mentioned by Andre. So do you power down your system when changing drives?
Guy Randle
www.rosewoodrecording.com
www.drumsondemand.com
Old 04-17-2007, 09:33 PM
[…] I haven't had the fw problems mentioned by Andre. So do you power down your system when changing drives?
I’m not here spewing FireWire and Brimstone — I am pleased to hear you have not experienced any problems such as the ones I described. I hadn’t experienced any problems hot-plugging/unplugging FW drives until… the day I experienced problems (and those were ugly).
The root cause of the problem tends to be blamed on the design of the FW connectors. In addition to data, FW also carrie power and — under the right circumstances — grounding for the latter goes missing during the act of plugging and/or unplugging.
Yes, I power down before adding and/or removing drives.
IHTH.
Andre Knecht
Old 04-17-2007, 11:05 PM
studiojimi's Avatar
studiojimi studiojimi is offline
listen and heed andre's suggestions and live long and prosper!
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
Help me unmount my network drive in Workspace. Dizzi45Z Pro Tools TDM Systems (Mac) 23 04-27-2011 12:11 PM
Unmount issue in Workspace Superfool Pro Tools TDM Systems (Win) 0 11-18-2010 02:10 PM
"unmount" drive feature gone? pt 7.4 cs2 track Pro Tools TDM Systems (Mac) 4 01-08-2008 02:38 PM
Unmount drive Feature Request TommyT Pro Tools TDM Systems (Mac) 3 05-27-2007 01:44 PM
