Old 02-12-2007, 07:59 AM
PTGuy PTGuy is offline
Default Applying multiple fade outs only
I need to know how to do the following and can't find this info anywhere in the manual...
I have about 100 regions that I have created via strip silence. I need to know how I can apply fade outs ONLY to all of them. The reason is because I need a longer fade out time than fade in.
Any ideas?
Old 02-12-2007, 08:18 AM
mhmh mhmh is offline
Default Re: Applying multiple fade outs only
PT doesn´t have this feature. All you can do is put the fade ins to square, but obviously that won´t solve your problem.
Martin
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 02-12-2007, 08:53 AM
You could save the session as PT4, import to Avid AudioVision. Apply the fades. Save as ProTools and import back to ProTools.
Or you can OMF-transfer the session to an AVID Mediacomposer apply the fades in a few seconds and OMF back to protools.
Meaning: ProTools is lacking a feature.
frank.
PTHDnPCIe 2024.6 (OSX13.6.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 02-12-2007, 11:20 AM
BlueDog BlueDog is offline
A work around would be to apply the fade outs you want, with fade in shape set to square. Then audiosuite the regions using gain plugin set to 0 gain change and 'region by region'. Then do the fade ins with fade out set to square. It's not pretty but probably faster than one at a time. I would also duplicate the play list as you go, so there is a way to backtrack any problem fades.
applying cross fade to several clips at once vudoo Post - Surround - Video 2 11-04-2012 09:56 AM
multiple fade outs key command? glideman Pro Tools 9 6 01-12-2011 10:17 AM
Fade-In and Fade-Out on Multiple Disjoint Regions holden Pro Tools TDM Systems (Mac) 2 11-30-2007 01:22 PM
How to apply fade-ins and fade-outs on selected regions? Halstein Pro Tools TDM Systems (Mac) 2 05-09-2007 03:07 PM
Applying edits to multiple tracks mwpmorris1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2006 01:35 PM
