Old 08-14-2005, 06:31 AM
Jon_Atkinson Jon_Atkinson is offline
Default Aurora Fuse-X
For all those following the previous thread on the DUC, Richard Fairbanks has done some exhaustive tests on this......
Check it out here
Let me be the first to thank Richard for taking the time to put this through it's paces!
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 08-14-2005, 07:13 AM
Default Re: Aurora Fuse-X
Yes. Very nice. The most interesting part is the info that PT only plays back in Sync when you generate TC at the same time through the Sync I/O. I wonder why this secret info isn´t mentioned in the manual as far as I know. Since PT either chases TC *or* generates TC does this mean that when chasing TC the audio played back from PT is randomly triggered also in between frames?
Frank.
PTHDnPCIe 2024.6 (OSX13.6.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 08-14-2005, 08:38 AM
If Richard is reading this, your evaluation is excellent. However, I think your SATA drive has 7200 RPMs, not 7600. Is that a typo?
Old 08-14-2005, 01:22 PM
minister's Avatar
minister minister is offline
richard reminded me of this fact and then i dredged up a memory of talking to a DIGI tech before i bought a sync i/o (i was having a problem with pulling code) and he mentioned that it was the only way for PT to detect the frame edge.
from page 65 of the sync i/o manual:
However, when the clock reference is set to
Video, the positional (time code) reference circuitry
(labelled Time Code and Window Dub
Circuit in the illustration) is not switchable.
This is because the positional (time code) reference
circuitry is always used to derive time code,
whether SYNC I/O is reading incoming time
code or generating new time code. Even in Generate
mode, SYNC I/O needs to use this circuitry
to detect the frame edge of the video in order to
generate time code.
so, no, i don't think it is randomly triggered, but it may not be perfect all the time. putting it online is the only way for it to determine (sample accurate?) exact frame edge.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 08-14-2005, 02:15 PM
Someone from Digidesign told me that sample accuracy is +/-2 samples when working with NTSC.
Old 08-14-2005, 03:42 PM
minister's Avatar
that's awesome. thanks chief!
Tom Hambleton CAS
IMDb
-Starcrash
Old 08-14-2005, 05:07 PM
Brandonx1 Brandonx1 is offline
Hi Richard,
Sorry if this is a stupid question. I'd like to be able to read Mojo or Avid video with the fuse-x card. Will it do this if the avid codec is installed? Also if it will output a let's say avid DV 25, would I be able to just import a AAF with video in it and start working like I can with a Mojo (in this scenario, the video would not be re-rendered with BITC just flattened)? Thanks for the help.
Peace,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 08-16-2005, 11:51 AM
Mike Stroven Mike Stroven is offline
This should work just fine with the Avid codec. It definitely works with DV, but I'd like to hear if Richard has tried with Avid's software codec loaded...
PT 7 and Aurora Fuse-X? jnowak Pro Tools TDM Systems (Mac) 4 02-14-2006 09:16 AM
Aurora Fuse-X Matt82au Post - Surround - Video 12 02-01-2006 04:44 PM
Where to buy an Aurora Fuse? Saar Pro Tools TDM Systems (Mac) 3 04-21-2002 09:01 AM
Aurora (still con) Fuse(d)!!! pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-03-2001 04:43 AM
Aurora Fuse & PT in same CPU??? rosindabow Pro Tools TDM Systems (Mac) 2 01-14-2001 01:02 AM
