Old 03-19-2004, 09:15 PM
TheLP TheLP is offline
Default Importing MIDI into Protools
When I try to import MIDI files the screen just refreshes and nothing happens, it doesnt appear newhere and I dont see it on the tracks any help? I searched for it but didnt get ne info.
[TheLP]
Old 03-19-2004, 09:25 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: Importing MIDI into Protools
The original Midi file needs to to be SMF-0 or SMF-1. Use the Inport Midi to Track and the midi regions should create a new track at the bottom of the session. Did you look down there? Also, the regions will appear in the Midi regions list at the bottom right. Are they there? Can you drag them to a midi track?
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 03-19-2004, 09:37 PM
yea they dont show up there either and how can i check if its SMF-0 SMF-1, thanks.
[TheLP]
Old 03-19-2004, 09:40 PM
Cliffy_Boy's Avatar
You need to export them from the original appliaction as SMF. For example, you can't take Cubase midi files and import them until they have been exported as SMF ( Standard Midi File)
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 03-19-2004, 09:42 PM
alright yea its in SMF format
[TheLP]
Old 03-19-2004, 09:45 PM
Cliffy_Boy's Avatar
They should import. I do it all the time. Check again in the midi regions list. Tell me exactly what you are doing to import them.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 03-19-2004, 09:48 PM
Alright I have the beat in reason on the ReDrum, and export it and save it a a SMF. Then I go to Import MIDI file to.... I double click and the screen refreshes and nothing pops up.
[TheLP]
Old 03-19-2004, 09:49 PM
Cliffy_Boy's Avatar
BTW - ndo you hit the ADD Region to the box before you import? You select the files one at a time and then hit add region and the file should move into the next box. Then you select import.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 03-19-2004, 09:52 PM
if you have to select before you import then no cause ive never selected the button before. I remember seeing it somewhere but i forget :|
[TheLP]
Old 03-19-2004, 10:01 PM
Cliffy_Boy's Avatar
The files that have been exported should have the extension .MID . You Import Midi to Track, select Keep Existing and the file should appear at the bottom of the edit window. And in the Midi Regions List.
Are you sure there is nothing there ? Try importing another midi file you may have instead of a Reason one.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Protools 10 not importing MIDI tempo changes ivmmusic macOS 1 08-15-2012 07:03 AM
Importing midi files into ProTools 8 memmms MIDI 10 05-06-2011 07:50 AM
Importing midi files into ProTools 8 memmms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-27-2009 01:54 PM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
Protools INSTANTLY crashes when importing (USB midi issue?) Pony Slaystation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2007 12:57 PM
