Old 06-21-2024, 10:07 AM
Bender Bender is offline
Default How to Delete and Reinstall PT
My file must be corrupt
I can't install it after using a suggested fix for eliminating the "Install Helper Tool"
Now the icon just bounces in the dock
Can I get instructions for deleting and then installing
PT Artist
Thanks
Old 06-21-2024, 10:27 AM
Default Re: How to Delete and Reinstall PT
Can you maybe keep your problems in one thread?
You did exactly what after being told not to try to delete the helper app in your other thread? https://duc.avid.com/showthread.php?t=428862
The easy way to uninstall Pro Tools is by dragging the app bundle to the trash, and empty the trash, it will not remove every vestige of the app, but should be good enough for whatever problem you have created.
Who knows exactly what silly thing you did, but normally, extended bouncing in the dock is caused by macOS having problems contacting Apple app signature revocation servers, typically when local networks are misconfigured. I have written about this many times on DUC you can find those posts with a google search.
Old 06-21-2024, 10:41 AM
BScout BScout is offline
just install again. You've damaged the Pro Tools app by doing what you did. Installing again will replace it. No need to uninstall first.
And also don't do things like this when told it is a necessary process. That other thread couldn't be more clear. What's your issue with the helper process anyway? It's been part of Pro Tools for a while now and you only have to approve it through macOS security once after an installation and you never see it again.
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.2RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 06-21-2024, 02:24 PM
Darryl I thought I was keeping it in one thread
My Cancer really messes with my mind and things that used to be simple never are anymore. I could not work in the studios I used to. They would show me the door for sure
Darryl you said
"Helper is a part of Pro Tools you don't get rid of it."
Then why does it ask for my username and password every time I start Pro Tools. It did not do that before
The Silly thing I did was click on this link looking for help
https://duc.avid.com/showthread.php?t=423106
Thanks guys for the help
Old 06-21-2024, 03:01 PM
Hey if you are still having problems if you say/give us a bit more context we can help more. Including macOS version, Pro Tools version (e.g. "2023.12", and the model Mac you have, describe the Mac config as best you can.
You can't remove the Helper app, but you should not be seeing it ask you each time you start Pro Tools.
Then why does it ask for my username and password every time I start Pro Tools. It did not do that before.
Did not do that before what? What exactly got changed that caused this?
And BTW if you were following these instructions:
https://avidtech.my.salesforce-sites...er-tool-prompt
You were doing the right thing and are not just removing the helper tool. You need to follow those directions *very* carefully.
And it may be there is some other issue going on.
And the reason for pointing out in the other thread that you can (or maybe should) remove Avid Link, that is a completely separate app that can cause problems, like messing up product updates/installs and you are better off downloading the installers manually from your Avid.com account. Sometimes people call that a "helper app" so I was not sure if you might mean that. If you want to uninstall Avid Link the unisntaller is in /Applications/Avid/Uninstallers
After you install Pro Tools again *if* it's still bouncing in the dock one test you can do is to completely remove you Mac from any networks, disable WiFi, unplug/turn off any other networking. Reboot the mac--now it's competently isolated and see if Pro Tools starts up faster without the long bouncing. If so that's pointing to likely misconfigured network where macOS thinks it can reach the apple revocation servers it needs to at apple.com but where it can't actually get to those servers on the network and it hangs bouncing waiting (macOS on a fully disconnected Mac knows it can't reach those servers and just skips over that). If you have problems there I or others here can help you sort that out.
Old 06-21-2024, 10:09 PM
MacBook Air
Chip Applie NT
16 gigs of Ram
Sanoma 14.41
Mac HD
External HD 1 TB
Regarding the helper app
I was using it for a long while and then I started getting a request for a username and password every time I tried opening PT
I did nothing different it just started asking
I tried a fix someone posted on the DUC and it corrupted my Artist app
Now I am installing the latest version of Pro Tools Artist
It says I first have to Download the Avid Link app
I download it and it goes into my downloads folder
I can not open the Avid Link 24.5 mac pkg
It will not open ( I know how to open compressed folders)
A lot of people are having this issue
Can I download Artist (I have been using it for a long time) from an installer and not use this Avid Link
I use lots of music software apps Logic Pro, Reason, Garage Band, and nobody makes you jump thru hoops like Avid. I like editing audio in PT. I have been for over 20 years on TDM, HD, Native. This is crazy
Old 06-21-2024, 11:50 PM
As I mentioned Avid Link can cause more problems that it is worth. I would not download it. What problems you have had are likely not related to Avid Link, and you may never have any issues because of it, but I'd just do Pro Tools app and plugin installs manually. Like many of us have done for many years...
Yes Pro Tools typically has the worst installer related problems and worst compatibility of most DAWs, you can minimize that pain by avoiding Avid Link and generally sticking to the Avid approved compatibility table: https://avidtech.my.salesforce-sites...tibility-Chart
If you already have Avid Link installed just ignore for now (You'll uninstall it later below).
You can download the Pro Tools installer directly from your Avid.com account.
Go to www.avid.com
Log into you user account there. (Green User Icon/"Log In" in top right header)
Once you give your user name and password and are logged into the account.
Select "My Products" in the Account menu (Green User Icon/"Account")
You'll see one or more broad black lines, one saying "Pro Tools Intro"
Click on the aqua colored "(V) VIEW Software Download Links & Product Details" to expand the download menu below.
You should see "Pro Tools 2024.6 Mac (DMG) 5.81 GB" click on that to download the latest 2024.6 version of Pro Tools.
That will download the installer "Pro_Tools_2024.6.0_Mac.dmg" to your Mac (usually to ~/Downloads)
Before running the Pro Tools installer double check that your Mac security settings are correct:
System Settings > Privacy & Security > Security > Allow Applications from [App Store and Known Developers]
Double click on the "Pro_Tools_2024.6.0_Mac.dmg" icon to install Pro Tools.
Installing Pro Tools will also install Avid Link even if you did not have it installed before. So before doing anything else go to /Applications/Avid_Uninstallers/Avid Link/ and run "Avid Link Uninstaller.app".
Old 06-22-2024, 06:23 AM
Thank you for the detailed instruction
Avid would only give me that info if I paid extra
I followed your directions exactly and everything is working ok
I can't believe the Avid Link app is such a problem
IF ANYBODY HAS ISSUES WITH THE AVID LINK AND COMES UPON THIS POST. IGNORE IT AND FOLLOW DARRYL'S DIRECTIONS... THEY WORKED PERFECTLY!
Thanks again Darryl
Mbox driver reinstall-reinstall-reinstall j.thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-22-2015 11:34 AM
To Delete or Not to Delete...that is the question DonaldM General Discussion 14 11-06-2013 04:52 AM
Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database delete MWPOP macOS 10 08-19-2013 05:19 PM
Delete files while reinstall Win XP!? xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-26-2004 06:57 PM
In case delete region, my PT 5.1.3 delete all regions on track. What is it? kwarkot Post - Surround - Video 0 12-04-2002 12:38 AM
