"Some Melodyne track data can't be found." Error
Hi all,
Did some ARA2 editing using Melodyne yesterday and in general I really like the integration. However today opening the same session I've got the following error: ------ Some Melodyne track data can't be found. Melodyne edits on affected tracks may not playback correctly. Track "LVox 1" ------ I haven't dived into the session to find out exactly what "may not playback correctly", but any thoughts would be much appreciated. Running latest version of Pro Tools, latest version of Melodyne Assistant on macOS 10.15.7. Thank you. |
Re: "Some Melodyne track data can't be found." Error
This happened to me and I think I have an idea why I got it.
When I got this message, it didn't seem that I had lost any Melodyne Edits, but I had a session where it had mistakenly detected the track as polyphonic. I had put it down in a playlist and then as I moved up the clips to the main playlist, I realized it was wrong and had it re-analyze it to the right algorithm. When I looked at the bars on the clip in the playlist, they still displayed as if they were still detected in polyphonic, but when I put the clip on the main playlist, it would be in the correct mode. So I'm wondering if the missing "Melodyne Data" it was saying had something to do with the old Polyphonic detection it was still thinking it needed from the playlist, but actually wasn't needed or used in my session.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
That sounds like it could be very similar to my issue too, both the playlist and polyphonic algorithm side of things.
I've delved around and can't find anything missing. I did find the "compare" button in the Melodyne editor though which is quite useful for toggling seeing and hearing the track before and after tuning! I think I've got my head around it all now and am absolutely loving it! I've been throwing all sorts of nasty edits and multiple clips with fades, clip gain etc. and it seems pretty solid. Only thing that I would like to see is the waveform in Pro Tools update when doing timing adjustments. Perhaps wishful thinking there! |
I do LOVE that if you change tempo, Melodyne will stretch with the tempo changes.
Interesting. Can this be defeated, perhaps by setting the track to Samples vs Ticks, or via another setting somewhere? I can see where there might be a reason to not want Melodyne to automatically adjust an audio track's tempo when adjusting the session tempo.
Scott Gatteño |
"Commit" or "Bounce" Non ARA 2 Melodyne Track? | Sparky1 | Pro Tools | 6 | 09-30-2022 10:52 PM |
Found a cure for "Access Violation" error! | Aargl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-09-2013 06:34 AM |
Once again "Content Not Found error with Strike" | rockme | Virtual Instruments | 13 | 11-11-2010 09:27 AM |
-43 Error "file or folder note found" | acacia | Pro Tools TDM Systems (Mac) | 3 | 04-14-2010 01:00 AM |
emergency. "error 35-Volume not found". | rjd2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-28-2009 05:24 PM |
