Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-30-2022, 09:28 AM
Default Re: MTRX Studio ADAT sync issues with external Audit ASP880 Mic Pre
Originally Posted by rknaub View Post
UPDATE- Ordered some new ADAT cables and that fixed the problem. Even though I tried two other cables before ....
Thanks all for your help and suggestions.
Glad you got it sorted! I have been bit by the multiple bad ADAT cables situation in the past and it's always a forehead slapping moment, lol.
Scott Gatteño
Old 10-11-2022, 02:41 AM
steins steins is offline
Originally Posted by steins View Post
Just curious why you would use the MTRX Studio's WC as master instead of the Big Ben? I'm using the Big Ben to provide WC for a MTRX Studio, 3 Avid I/O's and a couple of Adat AD/DA converters with Ext. WC (including an older ASP800) and it's been rock solid throughout the years with various converters. Do you think the MTRX Studio's clock is better than Big Ben? If so, I might have to switch
Stein Tore
Originally Posted by Darryl Ramm View Post
We've been down this rat hole multiple times. No quality modern interface needs to be "improved" by running external magical clocks.
If you need fancier clock boxes to physically just drive different devices/fan out clock signals enough then great. But there is just no other justification for this stuff, and I'll eat my hat if anybody can show an audible difference in double blind tests.
Hope the OP got the original problem solved...
I agree, hence the question regarding the MTRX Studio and me still happily using an ancient (by todays standards) clocking device. I'm glad nothing has changed .
Stein Tore Sønsteli
Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock
Old 10-13-2022, 07:12 AM
creativecontrol's Avatar
I've been bit by this as well. Don't buy cheap cables.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Connection Issues with MTRX Studio Ooptron Pro Tools | MTRX & MTRX Studio 10 09-26-2023 02:34 PM
BURL ADC with ADAT connection into MTRX Studio ursoctba Pro Tools | MTRX & MTRX Studio 13 01-16-2023 01:55 PM
Sync IO into a MTRX Studio IrelandM Pro Tools | Sync X & SYNC HD 11 10-31-2022 05:47 AM
ADAT with MTRX Studio domilik Pro Tools | MTRX & MTRX Studio 8 06-18-2022 07:15 AM
MTRX Studio and DADMan UI issues Skwaidu Pro Tools | MTRX & MTRX Studio 22 05-18-2022 01:41 PM
