Old 07-26-2014, 08:38 AM
kw88keys kw88keys is offline
Default syncing strike to click track
On PT11 (using 11.2) I CANNOT get VI drum patterns to sync with my click track. Same problem whether it is Strike or SampleTank 3). Works fine on PT 10. Is there some simple setting I am missing that enables MIDI VIs to skync with the click? To further clarify, I'm not talking about a slight delay compensation issue - they just totally disregard the click.
On Windows 7, 002 controller (which works fine with PT11).
Last edited by kw88keys; 07-26-2014 at 08:40 AM. Reason: added further clarification
Old 07-26-2014, 09:35 AM
Default Re: syncing strike to click track
ok, I think I worked this out. The beats were set for 1/8 notes. When I switched to 1/4 notes in the metronome everything syncs. However, I would still like to hear anyone's thoughts on this if there is further insight. Thanks for reading and/or posting in advance. Kent
Old 07-27-2014, 11:27 AM
nigelpry's Avatar
nigelpry nigelpry is offline
Also ... something to be aware of with strike ... which I mentioned in posts put up within the thread about the delay compensation bug for multi out VIs ...
If you record audio or MIDI using strike's in-built recorder, and then drag/drop onto a track's timeline in the edit window it only comes out correctly if the song's tempo (and therefore click track) are fixed tempo.
Otherwise it drifts out of sync, regardless of whether the relevant track is set to samples or ticks.
The solution, at least with the MIDI recorder, is to copy the midi notes that trigger the various Strike patterns to an area beyond the end of the song, where the tempo is fixed, record using the MIDI recorder in Strike, and then drag/drop into the timeline at that same point.
Once the MIDI region is on the timeline, you can now move it to an area of the song that has tempo changes, and providing the MIDI track is set to ticks, all the notes will stay correctly aligned to their intended bar/beat positions.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Syncing Strike to transport krcassid Virtual Instruments 3 01-28-2012 03:54 PM
syncing click to an imported track abbiehuxley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2008 09:15 AM
Syncing midi drum machine to RTAS Click Track espada3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2005 08:58 AM
RMX drums not syncing with internal click track magilbert MIDI 3 08-01-2005 03:47 AM
MIDI track and click syncing MrMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-07-2002 06:11 AM
