Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #31
Old 06-07-2020, 10:57 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: Building Orchestral Template, but PT Hangs
Originally Posted by falcowe View Post
Sorry this is going to be a newb question but what are you talking about when you say scripts Michael and/or massivekerry? Obviously it has something to do with how the VI's function but I'm not clear what exactly this script is. (I am not a programmer :))
Scripting is an internal Kontakt feature that allows developers to do things “under the hood” beyond just triggering a sample per note. Things like round robins, legato transitions, in-patch program changes, performance-sensitive articulation switching are all thanks to scripts that tell the instruments what to do. A great example is any of the “Total Performance” string patches from Spitfire. You play quick and hard, it’s Spiccato, gently and it’s Sustain, Connected and it’s legato. All in “real-time”, while managing all of the samples for each articulation, dynamic level, round robins,, multiple microphone positions (additional samples) and any triggered CCs for dynamics, vibrato, etc. while every other thing in your session is running. It’s kind of like driving while talking on the phone, eating a bagel in one hand, a coffee in the other and driving with your knees. If there’s not much traffic, and you’re in a premium, smooth ride, you ...might... be okay. But try it on a packed freeway In a 10-year old beater with everyone doing 15 over the speed limit...
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
  #32
Old 06-08-2020, 12:19 AM
Marsdy Marsdy is offline
Originally Posted by massivekerry View Post
One (kind of separate but somewhat related) thing to say in favor of VEP is that the Decoupled instances do cut down Save times. I’ve seen big DAW-hosted-Kontakt-Instruments templates in PT, Cubase and Logic, and when you have a bunch of instances (or even a particular few heavily-scripted instances) the Save time is OB-SCENE.
Good point - yes save times are way too long unless VE Pro is decoupled. It’s just unworkable with a lot of Kontakt instances. That’s another reason why I don’t host in Pro Tools and use VE Pro.
Dave Marsden
UK
  #33
Old 06-08-2020, 12:29 AM
Rectifried Rectifried is offline
Kontakt or omnispere or dive or or even its own mini grand ... Protools is abysmal to a freakish inept level in handling VI ...
if you want to deep dive in doing score go to VIcontrol forum/Sampletalk ... I lurked and a bit to get a handle on the craft of mock score and esp library’s .as it was less on YouTube then
. I think I saw one person once say they used pt to score .. many might a have a copy for delivery stems
But really ,no one used it .Nobody..
I Finally had to jump to Something else so I went Ableton ... logic and Cubase and digital performer are top 3 In Vi orch score world
Every year I think pt will handle it and ..... no,,
Putting time in on a working template and have the daw crap out is a (ahem ) drag ...Believe me
Watching yt vids of dozens of loaded VI with articulations and real time playing On other daws
Then sad trombone ...pt
Since you have a mac$$$$ Logic prob will be your best bet as I think it would / should be optimized for Apple-y love
Btw you were so generous during your nobody special Years helped me alot with my pcm96
And when I sold it once knowing harman might not update the drivers
Cheers
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
  #34
Old 06-08-2020, 03:31 AM
Michael Carnes's Avatar
Michael Carnes Michael Carnes is online now
Development Partner
Moving along, I've managed to get everything I'm likely to need into a VEPro project. This is a first. RAM-wise, I'm up over 200GB. Pro Tools would mess the bed by the time I got to 60GB or so. So now I can load the VEPro project and hook up in Pro Tools (insert any other DAW name). The orchestra is large enough that I have to use a half-dozen instantiations in the project.
This brings up the issue of the thread-count per instantiation. This feels archaic: a little like screwing around with the core count in Pro Tools 10 (something I don't miss). VEPro suggests the possibility of turning on multithreading in Kontakt itself and keeping the per-instantiation thread count low.
Does anyone have experience with this? By the way, thanks for all the helpful comments.
  #35
Old 06-08-2020, 04:31 AM
I’ve been messing with thread count per instance for years but always gone back to the default of two threads. Below that I get clicks and pops, above two threads CPU usage in PT starts going up exponentially. Two has always been the sweet spot for me. I have tried to spread the load of my “orchestra” across multiple VE Pro instances though.
I think it’s partly dependent on user workflow. How many instances of VE Pro in PT, how many instances of Kontakt per VE Pro instance and so on. VSL recommend keeping the VE Pro instance count low as you say but that gets tricky with a large template in the 100s of GBs. I’m tending to have 16 Kontakts per instance. I’ve not messed with Kontakt’s own multithreading much as I’ve never found it makes much difference in VE Pro.
I’ve found the single biggest variable is VE Pro’s buffer multiplier. The higher the multiple the more CPU efficient it gets although at the expense of latency. Before my new Mac Pro I’ve always had this set to x2 and with a PT buffer of 256, I personally found this manageable. That said I’m looking forward to pushing this on my 16 core.
Dave Marsden
UK
  #36
Old 06-08-2020, 05:44 AM
Development Partner
I think it’s partly dependent on user workflow. How many instances of VE Pro in PT, how many instances of Kontakt per VE Pro instance and so on. VSL recommend keeping the VE Pro instance count low as you say but that gets tricky with a large template in the 100s of GBs. I’m tending to have 16 Kontakts per instance. I’ve not messed with Kontakt’s own multithreading much as I’ve never found it makes much difference in VE Pro...
Thanks Dave. That's all very helpful input. Please be sure to post back (here or in a new thread) once you get down the road a ways with your new Mac.
  #37
Old 08-27-2022, 10:07 AM
Sanctus Sanctus is offline
Hi Michael and all,
I just wondered if this has settled for you? I have been having problems with Orchestral Tools hanging creating havoc for PT and Ariel in OT tells me it's probably my Glyph Thunderbolt where I run all my OT (and Spitfire/Komplete CE). However my problem is worse in that when I create a .mov file it sounds fine but when I upload it to Youtube, I have glitches. I have no problems with Spitfire or Kontakt but Sine player? Yes. Any advice would be welcome as I'm lamenting between OT, PT and Glyph.
Anyone here using PT 12 for orchestral work (big template) vudoo Pro Tools 12 5 01-13-2017 05:28 AM
Orchestral Template KierONeil General Discussion 1 06-26-2015 02:46 PM
PT8CS2 Hangs on Building "Miscellaneous Views" whatever that means 25ghosts Pro Tools TDM Systems (Mac) 5 03-02-2009 03:21 PM
Orchestral VIs SixChurchStreet Virtual Instruments 1 01-05-2009 04:21 PM
Using orchestral samples vogue Tips & Tricks 3 02-26-2004 03:46 AM
