re-compress or leave normalized?
i used to compress all my vocal tracks then normalize them to get the best volume out of them i stopped normalizing vocal tracks cause i realized how bad it was was making them sound but now i have all these old sessions with normalized vocal tracks should i just mix em like they are or would compressing them again make them sound any better?
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
Re: re-compress or leave normalized?
YOU have your tracks - why not try it and see what sounds better or worse?
Normalizing (the usual way, peak normalizing), shouldn't have any negative effect on the sound. If it does, it's a small effect.
Quad 2.5 G5, 4.5G RAM |
from now on, instead of normalizing, increase your output level at the compressor. If you don't do this and normalize instead after compression, you will lose several of the lower bits by comparison. Increasing the output at the compressor itself preserves these lower bits.
Cavell Studios |
Watch out recompressing because compression ratios are multiplicative. Say you originally compressed the vocals 4:1, then compress them again at 4:1 the result is the equivalent of applying a 16:1 ratio.
Why not just use automation to balance out your vocals rather than re-compress. Given what you've done so far restricting the dynamic range even more doesn't really seem appropriate unless you are doing it for a sound effect. Cheers, marcus |
Poll: Compress or not to Compress | EvilElfBoy | Pro Tools TDM Systems (Mac) | 16 | 07-08-2009 12:14 PM |
Normalized audio file in root directory | avaldes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-14-2006 08:14 AM |
compress compress compress | bigd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 11-30-2004 10:09 AM |
EQ OR COMPRESS | quence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-25-2003 09:56 AM |
Do you compress on VOX on the way in | supercell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-11-2003 06:22 AM |
