Old 12-20-2023, 12:27 PM
christian kuntner christian kuntner is offline
Default Printing internal Dolby Atmos Renderer
Is it possible to print (not bounce) the output of the internal Dolby Atmos Renderer ? It seems that the "Renderer Out" (assigned in the Dolby Master Master Out) is kind of a hidden bus...so there's no way to route the Renderer outputs to another bus...or am I missing something ?
Any ideas ?
Thanks, Christian
Old 12-20-2023, 04:54 PM
tope d's Avatar
tope d tope d is offline
Default Re: Printing internal Dolby Atmos Renderer
Any ideas ?
Thanks, Christian
Hi Christian!
You can try this.
Create a new 5.1 Audio Track.
Set all individual you'd like to print on your track's Output to your newly created 5.1 Audio Track.
Make sure your new 5.1 track has a selected supported Output.
Record Enable your session then hit play.
Let me know if it works on your end.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 12-20-2023, 06:14 PM
its2loud its2loud is offline
Any ideas ?
Thanks, Christian
No. The workflow for the Internal Renderer to output an ADM Wav file by either doing a realtime bounce or offline bounce.
The 5.1 and Binaural or stereo live Rerender is generally for metering or monitoring within Pro Tools.
Old 12-21-2023, 01:36 AM
That's what I thought. So I'll continue using the external Renderer, create 7.1.4, 5.1 and Binaural Returns and be able to print those returns in pro tools.
Pro Tools 2023.12 Internal Dolby Atmos Renderer Questions and Setup Update bolisound Avid Pro Mixing General Discussion 3 12-15-2023 08:51 PM
Dolby Atmos Renderer v5.2 dominicperry Pro Tools 4 12-15-2023 06:54 PM
Dolby ATMOS Renderer KeyplayerG Post - Surround - Video 20 08-22-2023 09:08 AM
