D-Control keyboard+numeric keypad issue pls Help...
hi to all
Im using MacPro+Lion+Pro Tools 10 HD (in input Sources U.S. is selected) also I tried all others.. in my D-control (bought new about 4-5 months ago) there is a problem that I cant fix it.. The problem is when I press the command in software shows that I pressed alt option button.. when I'm pressing alt option shows command!!! also in numeric keypad + button doesn't work when Im pressing - it shows + *=- /=* = shows / num lock dosn't work I think this is hardware issue is there any fix or should I call the service to fix it out.. thx |
Re: D-Control keyboard+numeric keypad issue pls Help...
Somewhere on the D-Control keyboard you can select to let it behave for PC or Mac I believe, but my brain has a memory leak about the details...
Greetings, Thierry
http://www.a-sound.com/ |
Thierry is on to something. There is a little switch at the bottom of the D Ctrl keyboard that lets you switch between win and mac keyboard layouts.
You will have to take the keyboard out and flip the switch over into the correct position It is explained somewhere in the manual as well. Somewhere in the setup section in the beginning of the manual. Chris
Chris Lambrechts Applications Specialist- Live Sound |
thx I will try it and inform u :)
Atilla |
Thank you so muchh I just founded the bottom switch and now its working:))) thank you againnn |
Guys Im using protools 10 hd but some times needs to use cubase 6..
do you know can I use Cubase + D-Control when I open cubase the d-contrl is offline I cant get it online... thx |
No way to use in Cubase sorry.
http://www.ainsliegrosser.com/ MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio |
Numeric keypad. | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-14-2011 03:51 PM |
Numeric Keypad | MFR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-24-2009 03:58 PM |
!!!!!Procontrol with 7.3.1cs4- Numeric keyboard issue!!!!! | Cryos | ProControl, Control|24, Command|8 | 1 | 09-16-2007 10:20 AM |
Numeric keypad transport control feature request | Steve MacMillan | Pro Tools TDM Systems (Mac) | 4 | 02-03-2006 08:29 PM |
Numeric Keypad | russrags | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-24-2005 02:53 PM |
