ASIO / Wav Driver Problem (or maybe not)
I have a Digi002r and I'm using the ASIO driver to great success with Nuendo! Works great!
For some reason, I can't open a wav file Sound Forge 7.0, which is set to use the Digi Wav drivers, while Nuendo is open and using the Digi ASIO drivers. I get a message that says: "An unknown error occurred when opening the 'Digidesign Digi003: Chan 1-2' device". The wav file opens in Sound Forge, but as soon as I try to play the file I receive the error message. Is there a way to have Sound Forge and Nuendo open at the same time using the two different Digi drivers? The only workaround that I found was to install another sound card and use it's drivers within Sound Forge. I don't really like that workaround, as I have to use two of my inputs on the digi002r to get sound out to my monitors. BTW, I'm not using an outboard mixer. Thanks for your suggestions in advance! |
Re: ASIO / Wav Driver Problem (or maybe not)
Only one app can use the driver at a time - both the ASIO and WaveDriver both use the dalwdm driver.
Rail
Asio driver problem !? | minniPT | Windows | 18 | 12-10-2012 08:47 PM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
PRO TOOLS 7 ASIO DRIVER PROBLEM | instro001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-17-2005 07:57 AM |
002 ASIO Driver Problem | shipwrecked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2004 05:36 PM |
ASIO Driver Install Problem | splattstudio | Pro Tools TDM Systems (Win) | 9 | 11-05-2003 12:05 AM |
