Help - PTU can't see MTRX Studio via HDN TB3
Hi all, on the chance there is a pro tools MTRX fan that might see this on a Sunday and kindly help - I am sure this is easy to solve, its just me, PS I have googled for an hour and tried all the advice.
I purchased last week a HD Native thunderbolt unit which is connected via a TB2 to TB3 adapter to my Intel Mac mini Big Sur 11.3.1; the HD Native box has a digilink cable from its port 1 to port 1 of MTRX Studio. The Dadman app sees the MTRX studio via ethernet. Tick. Mac mini Big Sur 11.3.1 sees the HD Native thunderbolt connected (when I check system information). Tick My iLOK cloud account shows digilink io licence is active. Tick PT-U loads fine. Tick But when I check in PTU "Setup/Hardware" there is no MTRX Studio visible, only PT aggregate and Mac mini speaker. Any help appreciated! thanks. H |
Re: Help - PTU can't see MTRX Studio via HDN TB3
Most likely the HD Driver is being blocked by macOS security settings. Go to System Preferences->Security & Privacy->General and see if there is a prompt to allow the driver to run. If not, you may need to reinstall it and keep a look out for a pop-up window asking you to allow the driver access to the system. There have been a few threads of people that were having problems with the system not showing the pop-up, or giving the prompt to allow the driver. A search of this forum should turn up some additional info and advice if that's the case.
Scott Gatteño |
Thanks Scott will try this....nope, systempref|security does not show any blocks...will keep searching...
Interesting that the Dadman app shows a RED triangle against the Digilink 1 row in the routing matrix Last edited by Hud; 06-20-2021 at 10:58 AM. |
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
Jan hi
version 2021.3.1 cheers! |
This definitely feel like a driver issue as Scott mentioned.
Does your HDNTB have a red LED lit on it by the headphones? If you open Audio MIDI Setup > Audio > do you see HDNTB? Jeff |
Indeed you are right! Re-installed HD drivers with help from Avid support (thanks again guys) and PTU now sees MTRX Studio in setup|hardware.
Thanks for all your responses :) (I'm going to post another now to do with routing from PTU to MTRX studio after having watched the setup video on YouTube and scoured this forum!) cheers H |
MTRX Studio with HD I/O | nedd | Pro Tools | MTRX & MTRX Studio | 37 | 07-04-2023 04:58 PM |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 08:48 AM |
MTRX Studio LFE went bye-bye | remainanon | Pro Tools | MTRX & MTRX Studio | 4 | 02-20-2022 10:41 AM |
MTRX Studio | Philharmonic7 | Pro Tools HDX & HD Native Systems (Win) | 15 | 08-23-2021 03:16 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
