Cantar BWAVmixdown in AVID to PT?
Client uses Cantar mixdowns during AVID-editing. If I import the OMF from his system, whats the quickest and cheapest way of replacing the mixdown with the mono BWAV's (6) from the harddisk I have with all the production audio? TIA, Peter |
Re: Cantar BWAVmixdown in AVID to PT?
The quickset (and therefor cheapest) would be a conform using Titan.
Go to the aaton website. thereīs a workflow paper with details. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Even quicker and cheaper option next time is to not give any mixdown to editor, only the mono tracks. Or give both, but be sure that you get 6-track OMF (original tracks) back, when he/she is ready.
If you give them only the mono-tracks you will receive an OMF with whatever they thought was best with again all other tracks missing. At least thatīs my experience. Itīs almost impossible to drag all 6 tracks along while editing for an editor. Leaves almost no room for temp fx, music etc. In the end you still donīt know whatīs missing and what isnīt because not all takes are always recorded with full track-count. You can then spend your time reading all the reports and comparing the OMF or start with a 100% complete conform from Titan ;-) One note: The cantar does not write the track-name info into the bext chunk (only into the iXML but some AVID versions do not inject that into the avid files) so make sure the editor loads the productionsound using th ALE-file from the DVD instead. Otherwise you will end up with no track names in your OMF. Having the correct track names in the region is a huge help for dialog-work. frank.
Even if the editor will delete some tracks, it's the assistant editor's work to put the missing tracks back, before he/she makes OMF for sound post. Thatīs my experience, maybe I'm in lucky position. |
Also what I wanted to point out is that an assistant editor will also cost money so itīs not "for free" that someone puts in the missing tracks manually. Your initial point was that itīs cheaper to let the editor(s) do this. My point was that if an editor does it it will take time and therefor money. Once you have the workflow going it takes about 10-15 minutes to conform a reel with titan. With this in mind I wondered how it would be cheaper to let an editor do this manually for hours or maybe days (unless he works for little to no money). I wasnīt saying that this option is not doable. Just wondering why it would be faster and cheaper if someone else did it instead of a machine. On the other hand: On some films itīs sad to realize that the machines are actually payed better than the people ;-))) best, frank.
So that's it? Titan? Hmmm, that's 1500 euro isn't it...
I've heard people using a native Pyramix "light" version to do edl conforms, anyone doing this? And another question; last time I did this manually (replacing mixdown with multiple originals). Pro Tools would let me replace some of the regions with right clicking and choosing an alternate and not so with others. What is that all about? (still PT 7.4 here) |
frank.
does anyone here have firsthand experience with this?
i am dealing with a show and we are about to begin this workflow. - location sound delivers multi-mono bwfs and 2 channel guide track out of cantar - telecine delivers clips with 2 channel guide to picture editor - picture cut in avid - edl and location sound into titan for conform the trouble is that our dialogue editor says that the titan only conforms 2 channels of media. he says he hasn't been able to get it to conform 8 channels unless they are multiplexed and the avid database references these multiplexed files (instead of the 2 channel mixdown). we are trying to figure out the workaround. has anyone experienced this problem? thanks, matt |
How was the telecine done? Were the sound-role infos loaded into the avid via a FLEX or ALE-file?
Titan will conform whatever additional channels it finds given that the correct references are in both the EDLs and the cantar-files. Are you feeding Titan the original split-tracks form the cantar? They share the same metadata as the EDLs. frank.
rename your cantar rushs (and others soon) MAC OS | lunacymaze | General Discussion | 2 | 12-20-2012 03:31 AM |
FCP to PT, reconform of cantar files? | mr.armadillo | Post - Surround - Video | 13 | 04-18-2012 08:29 PM |
Cantar audio from Avid MC help needed | soundworx | Post - Surround - Video | 0 | 03-26-2012 01:57 AM |
cantar mxf -> Avid -> protools | mik | Post - Surround - Video | 9 | 07-19-2009 03:57 AM |
Soundminer and Cantar files | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-11-2006 03:27 PM |
