Undipped Dolby Atmos Mix
I am putting together a workflow and delvierable list for a Dolby Atmos production, I am more accustomed to traditional workflows, and one issue I have come up against and would like some help on is undipped stems and though this was the best place to ask. The content we work on is documentary with narration and we will be producting a Dolby Atmos Mix and from that a 5.1 and 2.0 deliverable. We would also like to then export an Atmos DM&E mix but naturally that will be dipped for narration and sometimes foreign language dubbing. What is then the process for creating undipped M&E or DME stems from an Atmos mix. Would you not do that and instead archive the ProTools session to revisit downstream or create a new session of the atmos mix and remove narration/dips to create an alternative Atmos mix that you could them produce undipped M&E and DME stems? We would like to end up with the following deliverbales and looking for advice on how to produce the undipped files Dolby Atmos BWAV ADM Dipped with Narration 5.1 Wav Dipped with Narration 2.0 Wav Dipped with Narration DM&E Dolby Atmos BWAV ADM Dipped DM&E 5.1 Wav Dipped Stems DM&E 2.0 Wav Dipped Stems DM&E Dolby Atmos BWAV ADM undipped DM&E 5.1 Wav undipped Stems DM&E 2.0 Wav undipped Stems Appreciate any advice anyone has Ian |
Re: Undipped Dolby Atmos Mix
Remember, you can offline bounce an ADM file within Pro Tools with all Re-renders included as long as the Renderer is included. I’m not sure of your system setup, whether your working with an RMU, multiple Pro Tools systems, dubbed workflow, Dolby Production Suite, etc. Also, depending on your Pro Tools version, some of these options may not be available to you, ie offline bouncing an ADM file. |
Before Dolby Atmos there was Ford Atmos | gives | Pro Tools | 0 | 12-31-2022 02:12 PM |
Is there a way to use a 7.2.4 Dolby Atmos home theater as a Pro Tools Dolby Atmos mix | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 19 | 09-14-2021 08:52 AM |
Dolby Atmos | IrelandM | Avid Pro Mixing General Discussion | 2 | 07-17-2017 01:00 AM |
Dolby Atmos - Do I need SRC? | budster | Post - Surround - Video | 4 | 03-24-2015 10:25 AM |
Dolby Atmos | mikevarela | Post - Surround - Video | 3 | 06-25-2012 07:13 PM |
