Old 11-21-2007, 11:35 AM
Crillzmcp Crillzmcp is offline
Default Pro Tools running while Control 24 \"OFFLINE\"
Hey Ive encountered this before but dont remember how I solved it last time. I have a Control 244 and Im running Pro Tools HD 7.3.1 I opened up a session and started working on it buit the control 24 stills says its "offline" so no faders come up or levels, basically all i can do Is control tehe volume from the control surface. I think I had to cghange a setting but not sure, anyone able to help me out?
Old 12-04-2007, 07:51 PM
The Missile Silo The Missile Silo is offline
Default Re: Pro Tools running while Control 24 \"OFFLINE\"
In Pro Tools go to the following:
SETUP > PERIPHERALS > ETHERNET CONTROLLERS
Click the box for ENABLE, PT will can your ethernet port.
Once it is done scanning, click on the first menu bar for #1, when the menu pulls down it should have the option for Control|24, select that and click OK to close out of the PERIPHERALS window.
That should do the trick!
Ron
ron [k]
Musician/Programmer/Engineer/Remixer
System:
PT HD v8.0.1cs2/PT 9 HD3 Accel, 96 I/O, 96i I/O, Control |24, Midi I/O, Sync I/O
___________________________
http://myspace.com/ronk
http://ron-k.net/studio.html
http://facebook.com/ron.k.music
D-Control ES goes offline intermittently. [email protected] ICON & C|24 9 10-07-2010 12:26 PM
Running a Yamaha aw4416 to control Pro Tools' transport??? Rhett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2008 06:34 PM
MacPro & Control 24 - Offline... Jamie Smith ICON & C|24 0 02-25-2007 02:42 AM
Machine Control running 2 Pro Tools via Keyspan? subwoof Post - Surround - Video 1 03-22-2006 12:16 PM
Pro Control goes offline Polyester ProControl, Control|24, Command|8 8 05-15-2000 03:41 AM
