Build errors on Windows: Conan
Code:
Error loading conanfile at 'C:\Users\rolan\.conan\data\nasm\2.15.05\_\_\export\conanfile.py': Current Conan version (1.54.0) does not satisfy the defined one (>=1.56.0). |
Re: Build errors on Windows: Conan
Hi, RRabien!
Thanks for reporting this. We are working on the fix but one thing you can try is setting the conan version to 1.56.0 or later in the config/requirements.txt file. This should override installed conan to the required version. |
Same error here on WIN.
Already updated the version vom 1.54.0 to 1.56.0 (and also tried 1.55.0) with no luck... Results in compile error: Code:
... run_build_method(conanfile, self._hook_manager, reference=pref.ref, package_id=pref.id) File "C:\Users\-USERNAME-\Downloads\PTSL_SDK_CPP.2022.12.1.0.547041\PTSL_SDK_CPP\config\.venv\Lib\site-packages\conans\client\conanfile\build.py", line 15, in run_build_method with conanfile_exception_formatter(str(conanfile), "build"): File "C:\Users\-USERNAME-\AppData\Local\Programs\Python\Python311\Lib\contextlib.py", line 155, in __exit__ self.gen.throw(typ, value, traceback) File "C:\Users\-USERNAME-\Downloads\PTSL_SDK_CPP.2022.12.1.0.547041\PTSL_SDK_CPP\config\.venv\Lib\site-packages\conans\errors.py", line 44, in conanfile_exception_formatter raise ConanExceptionInUserConanfileMethod(msg) conans.errors.ConanExceptionInUserConanfileMethod: openssl/1.1.1n: Error in build() method, line 762 self._make() while calling '_make', line 702 self._run_make() while calling '_run_make', line 657 self.run(" ".join(command), win_bash=self._win_bash) ConanException: Error 2 while executing nmake ... Thank you, Steffen |
Hello.
I can suggest the next troubleshooting steps that can be performed in an attempt to fix any Conan issues:
Windows Build | jauk | FireWire & USB Audio Interfaces (Win) | 4 | 03-17-2014 05:23 PM |
Conan talkes about Final Cut Pro | dr sound | Post - Surround - Video | 6 | 06-27-2011 09:53 AM |
Errors 9129, 6085, 9092 Intel i7 build | JasonStatham8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 08-05-2009 04:54 PM |
Conan O'brien & Andy Richter record ADR for anime. | JWalkerVS | Post - Surround - Video | 7 | 08-01-2009 04:32 PM |
Conan O'Brien: Foley | Ryan Young | General Discussion | 12 | 06-13-2009 12:43 AM |
