Old 09-15-2001, 05:26 AM
T-Way T-Way is offline
Default Can I rename a controller?
I'm in the 'Edit" window working on a 'Midi' track. I click on the 'Track Display Format Selector' (the one where you bring up notes, pan, volume etc.).
Right, . . . where it says add/remove controller, you are presented with a lot of 'undefined' controller numbers.
All I want to do is rename and match (in this case) my Supernova II functions. [It would also be nice to have the same controller number duplicated, but bearing a different name, for other midi gear].
Is it possible?
Tim
Old 09-15-2001, 06:18 AM
Zeus Zeus is offline
Default Re: Can I rename a controller?
It doesn't seem to be possible. [img]images/icons/frown.gif[/img]
Z
Old 09-15-2001, 10:34 AM
I guess it's another one for the wish list then, . . . along with ruler guides that go over audio regions like the bring to front, send to back commands in graphic packages.
Cheers for reply Zed . . .
Tim
Old 09-15-2001, 03:23 PM
accession accession is offline
Yes, please Digi...
- Can we please rename controllers in the next update?
- Can controllers for cc#7 (volume) and cc#11 (pan) please be included as part of the main (renamable) controler list? I have a Lexicon MPX 500 effect unit that has 16 knobs (well 4 x 4 functions that is) that use cc#1 to cc#16 by default - yet have no need for volume or pan control.
- The way I work is to have a template containing a series of audio tracks, plus enough MIDI tracks to cover every channel of every synth in my studio. Can a system be implemented that enables one to import MIDI set-ups from a master template? At present, whenever a new synth is added to the studio, it must be manually added to every session. If it contains 16 multitimbral parts, one is forced to recall the controller tracks for each part. Another problem I've just faced is by repacing my MIDI interface, I must now reconfigure the MIDI output info for every track of every session.
Thanks for listening.
Phil
Old 09-15-2001, 03:48 PM
And Digi, while you're at it, make it possible to define faders (or rotary pots or buttons) for any controllers on-screen, in the manner of the volume and pan controls. Say, you could have modulation depth fader on Midi track 1, portamento speed pot on midi track 2 etc...
And non-destructive realtime transposition, quantize, etc...! A must-have.
Z
Old 09-15-2001, 05:06 PM
Thanks Zeus.
That was another request I'd been meaning to put forward.
It could be laid out something like a collection of Aux Send mini-faders, or nicer still, in a user-definable layout with proper descriptions for each cc#, with the ability to save as a preset cc# fader set for a particular synth.
Phil
Old 09-17-2001, 12:32 AM
lwilliam lwilliam is offline
I'll hop on this one, too. The NI B4 uses a lot of "non-named" controllers for things like rotor acceleration/deceleration, "tube" brightness, overdrive level, etc. It sure would be handy.
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 09-17-2001, 09:54 AM
tommydee tommydee is offline
yo... howzitgarn' phil?
('tis ****ing nuts here in nyc.)
do you work at trafalgar studios?
my 2 cents for digi-wants: Rewire support for Reason. PLEASE!
peace to us all.
t.
Old 09-17-2001, 03:20 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by tommydee:
t.
<HR></BLOCKQUOTE>
No, I'm in Australia, but all our thoughts are with the people of the USA at the moment. Our country has also lost a considerable number of people in both the WTC and the hijacked planes. The situation is horrific.
Phil
Bus Rename Bug Audio_Vision Post - Surround - Video 0 09-05-2011 01:16 PM
Auto Rename in PT6.4.1 is odd Matt Stutter Pro Tools TDM Systems (Mac) 10 09-18-2004 02:45 PM
rename file ZEUSS Pro Tools TDM Systems (Mac) 9 11-12-2003 01:40 PM
Auto Rename Bug ? Blackfoot Pro Tools TDM Systems (Mac) 3 02-21-2002 10:14 PM
what good is auto-rename if they don't rename at the root level? graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-28-2001 01:14 PM
