2 QUESTIONS
MAC Power book G4 w/ 1G(2x512mb)
80GB Ultra ATA Drive @5400RPM Digidesign 002R Pro Tools LE LaCie 2d 160GB External Fire Wire Hard Drive I am planning on recording my band practice on 4 tracks w/ the 4 XLR inputs on the 002R and I wanted to record the 1 1/2 hour practice straight w/out opening a new session. Is this a problem? Also what order should I put the G4/002R/LaCie in. My G4 has a 400 and 800 input for Firewire. Thank You. |
Re: 2 QUESTIONS
The recommended path is Firewire 400 to drive to 002R.
The length of the session should not be a problem. |
Re: 2 QUESTIONS
If i'm doing my math right, you should be fine, as a 4 track session recording at 24-bit 96k will take up about 5.8 GB for 90 minutes. I would check with poeple who have run this long, but i don't belive there would be any major problems.
Support could possibly help. BTW, i'm getting this 5.8 GB figure by taking the amount of space 2 tracks at 24/96 for 5 minutes (165 MB), multiplying it by 18 (there are 18 5-minute divisions in 90 minutes), then doubling it (for the 4 tracks). Use this if you wish to check my math. Tell us how you fare. |
Re: 2 QUESTIONS
When recording for long periods of times, you may wish to change the DAE playback engine from it's default level of 2, to a higher level 4 or level 8.
24-bit files at a sampling rate of 96k are 16Mb a mono minute. One 90-minute audio file would be 1,440Mb Four 90-minute audio files would be 5,760Mb or 5.76Gb. DJ Insomaniac is correct on the math. |
Newbie questions on laptop PC selection - basic questions - thanks... | half drag | Windows | 0 | 01-04-2011 01:12 PM |
Crisis... I need to know it all now. Ram Questions. CPU Questions. Please......... | Target Earth Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 01-04-2002 12:20 AM |
Questions | jeffreyr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2001 09:52 AM |
5.1 questions....and OSX | prophei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-29-2000 03:56 PM |
Questions Questions | roxy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-26-2000 07:45 AM |
