Old 11-26-2001, 12:48 PM
terryinca terryinca is offline
Default No Record Enable Button
When I create a Auxiliary line-in track, no record enable button appears, so I can't record even when the track is receiving a signal. Recording on Audio tracks works fine. Is there a different way to record a stereo signal? Thanks.
Old 11-26-2001, 04:26 PM
Homer Homer is offline
Default Re: No Record Enable Button
You can't record audio on an auxiliary track, its only meant for sub-mixes, effects returns or external inputs, etc.
Think of it as a spare input for 'live' feeds.
Old 11-30-2001, 05:15 AM
clausiii's Avatar
clausiii clausiii is offline
to record a stereo signal, open two audio tracks and slide the one pan to left and the other to right, then enable record -> Bingo, start recording
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
HTML code is On
Record Enable button gets disabled... gilorlev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-30-2010 12:35 AM
Track one record enable button quit working? bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2010 12:20 PM
No Record Enable Button Kwasi J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2006 01:50 PM
Enable toolbar button labels? tperry Digidesign Hardware & Software 3 09-13-2001 06:27 AM
No Record Enable Button Appears lb1 Digidesign Hardware & Software 1 09-06-2001 09:36 AM
