Old 02-20-2011, 12:31 PM
JGold707 JGold707 is offline
Cool Mbox2 clicks on windows7 but mini works fine
Mbox 2 clicks and pops on PTLE 8.04. I am running 7, 64bit. I also have a mbox2 mini. It works flawlessly on the system. I tried removing all drivers and directing the found hardware wizard to the PTLE 8.04 update folder. No use. I tried play back engine settings, and all the usual. It sounds like a clocking glitch. It's easy to blame on the integrated graphics, but then why does the mini work. Do they share a driver?
< Computer >
Model: HP HP Pavilion dm4 Notebook PC
Workgroup: WORKGROUP
Host Name: Dm4
User: Lap top
< Processor >
Model: Intel(R) Core(TM) i5 CPU M 450 @
2.40GHz
Speed: 2.53GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 2 Unit(s)
Type: Mobile, Dual-Core
Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size, 2 threads sharing
L2 On-board Cache: 2x 256kB, ECC, Synchronous, ATC, 8-way, 64
L3 On-board Cache: 3MB, ECC, Synchronous, ATC, 12-way, Exclusive,
64 byte line size, 4 threads sharing
< Computer >
Platform Compliance: Intel Centrino Mobile Technology
Mainboard: HP 146A
BIOS: HP F.23 10/21/2010
Bus(es): X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
Total Memory: 3.8GB DDR3 SO-DIMM
< Chipset >
Model: HP Core (Auburndale/Havendale) DRAM
Controller
Front Side Bus Speed: 1x 133MHz (133MHz)
Total Memory: 4GB DDR3 SO-DIMM
Shared Memory: 34MB
Channels: 2
Memory Bus Speed: 2x 532MHz (1GHz)
< Memory Module(s) >
Memory Module: Hynix (Hyundai) HMT325S6BFR8C-H9 2GB DDR3 SO-
DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-
5)
5)
< Video System >
Video Adapter: Intel(R) HD Graphics (12 SM4.0 767MHz, 64MB
DDR3 2x533MHz, Integrated Graphics)
< Graphics Processor >
< Storage Devices >
SAMSUNG HM500JJ (500.1GB, SATA:466GB (C:) (D:)
hp CDDVDW TS-U633F (SATA:N/A (E:)
< Logical Storage Devices >
SYSTEM: 199MB (NTFS)
Hard Disk (C:): 442GB (NTFS) @ SAMSUNG HM500JJ (500.1GB,
SATA300, 2.5", 7200rpm, NCQ, 16MB Cache)
RECOVERY (D:): 24GB (NTFS) @ SAMSUNG HM500JJ (500.1GB,
HP_TOOLS: 99MB (FAT32)
Optical Drive (E:): N/A @ hp CDDVDW TS-U633F (SATA150, DVD+-
RW, CD-RW, 2MB Cache)
< Peripherals >
LPC Hub Controller 1: HP HM55 LPC Interface Controller
LPC Legacy Controller 1: Winbond W83687THF
Audio Device: HP P55/PM55/3400 High Definition Audio
Audio Codec: Integrated Device Tech 7605h
Disk Controller: HP P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1: HP P55/PM55/3400 USB2 Enhanced Host
Controller
USB Controller 2: HP P55/PM55/3400 USB2 Enhanced Host
Controller
SMBus/i2c Controller 1: Intel 801xx/63xx SMBus
< Printers and Faxes >
Printer: Microsoft XPS Document Writer (600x600,
Colour)
Fax: Microsoft Shared Fax Driver (200x200)
Printer: Adobe PDF Converter (4000x4000, Colour)
< Network Services >
Network Adapter: Bluetooth Device (Personal Area Network)
Wireless Adapter 1: Intel(R) WiFi Link 1000 BGN (802.11g (ERP),
AES-CCMP, 144Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
Battery No 1: 100%
< Operating System >
Windows System: Microsoft Windows 7 Home 6.01.7600
Platform Compliance: x64
< Windows Experience Index >
Current System: 4.7
<<< Operating System >>>
< General Information >
Full Name: Windows 7 Home Premium 6.1.7600
Kernel Type: Multiprocessor Free
BackOffice Components: No
Small Business Components: No
Terminal Services Components: No
Compute Cluster Components: No
Product ID: 00359-OEM-8992687-00010
Product Key: 4FG99-BC3HD-73CQT-WMF7J-3Q6C9
Registered Owner: bad fish
Registered Organisation: Hewlett-Packard
< Activation Status >
Name: Windows(R) 7, HomePremium edition
Type: Windows Operating System - Windows(R) 7,
OEM_SLP channel
Activation Required: No
< Data Execution Prevention (DEP) >
Supported by CPU: Yes
Applications Protected: Yes
Drivers Protected: Yes
< Virtual Machines and Runtime Engines >
.NET Framework: 4.0.30319
.NET Framework: 3.5.30729 (SP1)
.NET Framework: 3.0.30729 (SP2)
Windows Communication Foundati:3.0.4506
Windows Presentation Foundatio:3.0.6920
Windows Workflow Foundation: 3.0.4203 (SP2)
.NET Framework: 2.0.50727 (SP2)
< Default Key Applications >
Web Browser: Google Chrome
Address Book: Address Book 6.01.7600.16684
Anti-Virus: avast! Antivirus
Anti-Spyware: avast! Antivirus
< Session Settings >
Host Name: Dm4
User: Lap top
Time Since Start-Up: 3 minute(s), 16 second(s)
< OS Properties >
Debug Version: No
Security Present: No
Remote Terminal Session: No
< Boot Features >
Boot Type: Normal
< Automatic Update >
Active Service: Yes
Status: Notify but don't download
< Installed Windows Updates >
Windows Live Essentials 2011 (:Feature Packs, Windows Live (5.25MB)
< Available Windows Updates >
< Regional Settings >
User Default Locale: 1033
Country: United States
Language: English (United States)
Currency: USD
Time Zone: Pacific Standard Time
ANSI Code Page: 1252
OEM Code Page: 437
< Operating System Folders >
Windows Folder: C:\Windows
System Folder: C:\Windows\system32
Application Data Path: C:\Users\bad fish\Desktop
Programs Path: C:\Program Files
Temporary Folder: C:\Users\BADFIS~1\AppData\Local\Temp
< Performance Enhancing Tips >
Warning 1316: This copy of Windows contains Product
Activation Technology.
Tip 1324: .NET Framework 1.1 not installed. Install to
run legacy .NET applications.
Tip 1327: Java Runtime Engine not installed. Install it
to run the current Java applications.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
***** End of Report *****
UAD2/Mbox2/Windows7 jacen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-01-2012 11:13 AM
Protools 9.0.5/Mbox2 Pro/Windows7/Distortion and More Joeinlb Windows 0 11-12-2011 08:41 PM
Mbox2 Windows7 troubles chandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-13-2011 11:36 PM
Pops and Clicks on MBOX2 Mini only when PTLE is running dongemus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-01-2010 04:34 AM
HP DV90610ev works fine with Mbox mini sonicapg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-19-2008 12:57 AM
