Old 04-21-2008, 01:45 PM
maufau maufau is offline
Default Anyone know a \"select next track\" or \"record enable\" command
I have been looking for this for the longest, but I can't seem to find if there is a select next track key command or a record enable key command.
Is there?
Old 04-21-2008, 05:07 PM
sky88dd sky88dd is offline
Default Re: Anyone know a \"select next track\" or \"record enable\" com
You can use the letter "p" for select previous track and colon/semi colon(the one under p) for next track.
I don't think there's one for rec enable though.
Hope that helps.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Can u select the track by using rec/enable button ? JonLance Pro Tools 9 0 08-06-2011 08:32 PM
can't record enable a track macfreak86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2011 06:11 PM
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 10:41 PM
How to select next track & record enable with key command? JLEpperson Tips & Tricks 2 04-25-2008 08:05 PM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 06:08 PM
