Old 07-13-2008, 02:57 AM
beastie boy39 beastie boy39 is offline
Default 002 Rack Line input low level
I own a digi 002 rack, with a dbx 266 xl and a joemeek preamp connected to the line inputs 5-8.
dbx outputs are set to +4 dbu, joemeek delivers high level outputs and 002 line inputs are set to accept +4 dbu levels.
Despite all that, input levels shown in protools are hopelessly too low.
- dBx compressor (balanced) when used as an external insert (i.e: thru line 5 output-input) with no gain attenuation and output level set to 0 db come back with almost 10 db of attenuation or more.
- Joemeek preamp (unbalanced) with input almost peaking and output gain nearly at its max give max -16/-12db in protools
If someone has already encountered this kind of troubles or knows what it's all about; let me know..
Thanx <font color="#666666">
Old 07-13-2008, 11:30 AM
flommer flommer is offline
Default Re: 002 Rack Line input low level
Sounds like your gain staging is screwy somewhere... Figure it out part by part:
Does the Joe Meek have any kind of metering or an overload led? If so drive it until you are getting a hot signal at that point.
at -10 or at +4 on the 002?? Is this without going through the compressor? If, not try it that way to see what you get.
If I understand this correctly it sounds like a problem.. You're saying your settings should mean no attenuation, but it is attenuating anyway? Is there a bypass to test this?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
JAMLAB - Input Line level very weak - PT 7.3.1 cs4 JazzyJ Pro Tools M-Powered (Win) 4 01-18-2008 01:45 PM
Inputs 1-4 used as line-level on 003 Rack Everything 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2007 06:34 AM
Mbox line level input noise using keyboard egraham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-03-2003 08:09 PM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
can i run a line level into a hi z input ??? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2003 02:37 PM
