Old 06-12-2008, 02:57 PM
Ginger Ginger is offline
Default 2.5\" SATA in Firewire 400 case Yes or no?
I'm running an mbox (original) with 7.3.1 (cs whatever) on a G4 powerbook OS 10.4.9 with Dv Toolkit as my small portable system. It all works great. I would like to be able to run sessions (audio & video) off a 2.5" SATA drive that would be in a firewire 400 case. The specs don't cover this exactly. I know it's not "qualified" but has anyone done this successfully? I generally don't run video & audio off the same drive although it works fine for me on my "regular" size FW drives. I thought SATA is inherently faster than IDE. Obviously the transfer rate is dictated by the FW400 spec, but if sata is reading more data at a slower rpm than could it be 5400rpm sata => 7200rpm IDE in terms of amount of data being read/written? Meaning it would meet digi's drive specs?
I only need a few tracks; no more than 8 at 48k. I would just try it but the only case I can find locally is one I don't really like so I'd rather not get it right now if someone has tried this and it didn't work. (Of course, I need to do this today if it's going to be helpful to me.) I'm going out of town tomorrow and I'm trying to lighten my load.
TIA
Old 06-12-2008, 06:21 PM
Ziko Ziko is offline
Default Re: 2.5\" SATA in Firewire 400 case Yes or no?
I haven't tried this so can't give you dirdct experience, however SATA@5400 does not equal IDE@7200.
SATA v IDE = imperceptible difference in actual performance, cache size and rpm is what makes the difference.
Will you be able to run PT with sessions on this disk? Yes.
Will you hit a performance limit sooner? Yes.
So it comes down to how dense your mixes are, how many fades there are, plugin count etc.
Cheers,
Simon
Macbook Pro 2.4 GHz, OSX 10.5.5, PTLE 8 + MPT, 003R Factory, Apogee Mini-Me
SATA in a FW400 Case? Farmer Dave Pro Tools TDM Systems (Mac) 9 02-03-2005 10:38 PM
SATA drive in an external case??? K-Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-19-2004 10:17 PM
OT: Superdrive in a firewire case. Anyone ? Impala Pro Tools TDM Systems (Mac) 4 03-26-2003 12:28 AM
Firewire Case / Digi 002 brianres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-04-2002 01:31 PM
In Case You Wonder About Firewire... tuchel Tips & Tricks 6 02-23-2001 01:46 AM
