Old 04-30-2021, 02:31 PM
khj12 khj12 is offline
Default Subgroups/Mixgroups not working properly
Hi, I have a session working in post production.
I'm mixing from my regular template where I have tracks routed though Subgroups for Dialog, SFX, Music, etc.
1st thing I noticed that was different was that audio wasn't coming in to the subgroups like usual. Unless I had record mode or Input monitoring on.
I've double checked the routing and it's just the same and basic subgroup routing.
Dialog channel f.x. output to bus 3-4 (DX) and input on the subgroup channel 3-4 (DX).
Outputs are then just set to ouptout 1-2 on all subgroups as well as the master channel.
I've finished the mix and was going to bounce the files and send it today but same with bouncing it - It's just silence. Unless I input monitor it (which doesn't work ofcourse when bouncing) .
Hoping for quick suggestions! Thanks !
Old 05-01-2021, 08:57 AM
Default Re: Subgroups/Mixgroups not working properly
This is very confusing. By what you describe, it sounds like you are using AUDIO tracks as your sub-groups(which would explain why they need to be in INPUT mode). Must people use AUX tracks for this purpose as they pass audio under all circumstances(including Bounce to Disk).
ADC not working properly [email protected] Pro Tools 12 0 08-07-2017 03:19 PM
Not working properly trife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-10-2008 08:40 AM
Aux Sends from Subgroups Duardo VENUE Live Sound Systems 4 01-29-2006 08:29 AM
TC/E not working properly. twigstickley Pro Tools TDM Systems (Mac) 2 03-22-2005 10:12 AM
PT not working properly chainboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-21-2004 01:11 PM
