Re: Digi hardware - bizarre behavior - Digi you will lose this market share
I'm sure this won't sway your opinion, but half the HD studios in Nashville work at 48K, as do most of us here. If 96K is mandatory for your work, then LE is simply not the best course.
another thought, the whole 44.1/88.2 etc. you really need to analyze your situation. a great mix sounds great at 44.1. 96k will not save a bad mix. is it worth the extra drive space and system resources? some older plugs or vst's wrapped will not be compatible at this sample rate. how much of your music ends up being hammered with lossy compression and ending up mp3, or will that be the only distribution format?? does the client care???? are you really working and it will make a difference or demo'ing in your bedroom hoping for global domination??? is it just a **** measuring contest for you???? just some thoughts to consider... the "factory" in the 003 title means nothing but more plugins, it is nothing fancy.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
ADAT Optical = 8 channels at 48K. Its a standard thats almost as old as MIDI. Digi has nothing to do with this standard.
ADAT Optical (SMUX) = 4 Channels at 96K. Every interface I have seen that supports the ADAT standard at sample rates above 48K drops the channel bandwidth by 1/2. ADAT Optical (SPDIF or Toslink) = 2 channels at 48-196K. The Digi stuff uses the actual ADAT and SPDIF standards which covers the probably about 75-80 percent of the recording scenarios out there. I don't know anyone that records at over 48K on a regular basis. Would it be nice if the 003 would give you 4 channels of SMUX as a option? Sure! But very rarely does a company revise their existing hardware to add a feature that the majority of their users could care less about and may never use. Should they incorporate SMUX into the next generation of hardware? Absolutely!..... Unless its going to significantly increase the cost, push other features out and not be used by 95% of the users. And you still need a SMUX compatable optical pre's. Most of the lightpipe pres I see offer 8 channels at 48K. There are plenty of higher end pres that offer 2 channels at <48K but again these use the SPDIF format which Digi covers. I'm not saying Digi couldn't or shouldn't up their game but I be willing to bet that they've done some market research and weighed what the majority of users will actually use. I would be suprised if Sweetwater or any other large retailer is selling 10-20 Lightpipe pres for every ISA 428 or other high end optical preamp they sell. If you look at what LE users are buying its probably 95% inexpensive lightpipe pres. I have a Presonus Fire Studio Lightpipe. It will do 32 channels @ 48K or 16 Channels @ 96K. Guess what? None of the common light pipe pres go to 96K...... I bought it for inputs not SMUX support. By the time you have bought the Fire Studio Lightpipe AND enough converters to feed it 16 96K channels you could have bought a 96IO or 192. If you routinely need to record at 88-96K Digi makes some great systems for that too....and if you start pricing the actual hardware that you need to to achieve the track counts they are reasonably priced. If you routinely need to record more than 10 channels @ 88-96K perhaps you need something other than PTLE? Personally I would like to see a 003 with 8Pres, SMUX support, or something like ADAT bridge with no pres, or a 003 with a optional fader pack but its unlikely that any of this will show up until theres new hardware.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
adat at 48kHz is the way to go, get over it!
OCZ SataIII system, 2xWD Caviar Black - Asus P5Q Deluxe w/Intel p45 chipset - Intel Q6600, Asus EAH3450 ATI Video card - 8GB RAM (800Mhz) - Win 7 PRO SP1 - PTHD 9.0.3 - Aurora 16-VT w/AES16e - UAD 2 Quad 'seems to be working ok' |
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#16
Isn't it usually the case that 96khz is only used when scoring movie soundtracks ?
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us. |
#17
So, according to your logic... I am a totalitarian, book burning, lie preaching, Digidesign employee? Yes, my "prerogative" is 4 XLRs and everyone MUST only use those or else SUFFER THE FATE OF ETERNAL CONDEMNATION IN A FIERY PIT OF DEATH AND FIRE.... AND BURNING. DID I MENTION FIRE?! I am very aware that Digidesign creates multiple devices, this is why I also have an MBox 2 to go with my 003R. It's hard to stick my 003 in my backpack, so this works out well for me. I also do consider this "my concern" because people are voicing "facts" about Digidesign that simply aren't true... so when people come on these forums screaming about things they don't even understand... yeah I make it my problem, because I care about people not getting misinformation on these forums. Man, I am a horrible horrible person. (insert another fire/burning reference here) I never said there is only one purpose for anything, I simply said that there are many of us who do not share your frustration. Just because you don't like it, doesn't mean everyone doesn't like it. It's getting pretty clear to me, by the other responses that I'm not far off the point, either. But... I guess that just means we're all heretics and Digidesign employees. I do use my 03D via ADAT, but again... as I said before, I don't often record past 48k, and when I do, I tend to only require 1 or 2 mics. Thus, I will use one of the 8 ANALOGUE outs instead of ADAT. And since the 03D's optical is limited to 20/48... I rarely use the ADAT at all, since I often don't need more than 8 ins at a time. I am simply giving examples of how I use my gear. There have been plenty of other responses as well... (what was that about using HD in 48k?! BLASPHEMY!) are we all just pandering to Digidesign to piss you off? No. We are trying to explain to you that we all knew what we were getting into when we bought our hardware. I suggest you do the same. Saves a lot of headaches and heretics in the future.
#18
As far as 96k goes, it does make a difference when mixing in the box in one very important area that many over look, and that's aliasing in the plug-ins themselves at lower sample rates. This can be overcome at 48k and lower by being picky with your plug-in choice. It's probably not much of an issue with modern plug-ins though. 192k was nothing but marketing that did an absolute crash and burn. I see no harm with anyone posting feedback. Good or bad, frustrated rants or fanboy praise, it's still valid customer feedback. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#19
Even when using HD, I and those I know, primarily use 44.1 or 48 KHz / 24bit, and it hasn't kept us from selling projects or retaining clients. I say this only to point out that if AVID takes a dive, I don't think it will be over this. I do agree though that in a perfect world all of the useable sample rates would be available on all configurations.
We do need a new Native hardware line.
#20
Thank you!!! |
Bizarre behavior on D-Control | Mikey MTC | ICON & C|24 | 2 | 02-12-2007 10:09 PM |
Suggestion for digi to keep dominating market | brokemusician3 | Pro Tools TDM Systems (Mac) | 56 | 01-11-2006 11:33 PM |
romours ´bout digi goes into live-market??? | gregor rasek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-14-2004 11:03 AM |
Digi Market Dominance. | s0nguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 03-03-2004 06:55 PM |
Bizarre Premiere 4.2 Behavior | JKD99 | Post - Surround - Video | 8 | 02-20-2004 09:27 AM |
