I have a project to do for my audio recording class. I recorded a live performance and the left mic was louder than the right. I made a new session and put each mic(left and right) onto two mono tracks. I adjusted the gain on the right track. I edited both of them with fades and eq and need to consolidate them and burn them to a disc. How do i get them to consolidate together? Do I need to make a single stereo track, and how do I do this? Whenever I try to drag both files onto a stereo track it removes the gain adjustment to the right track. PLEASE HELP!!!!!
![]() Quote:
Chris
![]() Quote:
Thanks for the input, as I have a very similar problem that is most likely simply attributed to my lack of experience. I have two stereo guitar tracks that I want to combine into one stereo guitar track which contains the info from both of the others (basically making one track where once there were two, with the same sound coming out at the end). I want to do this in order to 1. reduce the track count, and 2. reduce the CPU usage by being able to eliminate to two original tracks and their respective plugs. I thought that I could simply set the output of these two tracks to, say Bus 9-10, create a new stereo audio track with its inputs set to Bus 9-10, record-ready the new track, push play and be done (the output of the new track would, of course be set to 1-2 like everything else). Wrong answer; no sound at all using this technique. Is there any way to route the signals from the two original tracks into a single track for recording so I can just delete the original tracks? They say there is no such thing as a dumb question, so if this is an exception, I apologize! ![]() |
Djjazzy,
the way you described is correct to create a bounce, you mention in you description that after record ready, you press "play" don't you mean press "record"? Are you on LE or TDM, if it is TDM then pressing the green input button allows you to monitor the audio without recording. Pressing play without input monitor on will play what is on the track, in your case which is nothing, if you press rec on the transport then you will record the file and hear it at the same time. Let me know if this is the problem Simon L. |
![]() Quote:
Now is where I hit "Play" (since I am in Punch mode, the track can start without having pushed the "Record"button). I think I am an idiot, though, because I would not be able to hear the audio from Guitar Track 1 and Guitar Track 2 until I actually hit the Record button, since they are being bussed, and not just being sent out 1-2 like normal. I thought I had done this, but now upon trying to recollect step-by-step what I did earlier, I may not have hit the record button, simply expecting to be able to monitor what would be recorded without actually recording it to the track since the New Combined Guitar Track was record-enabled. If I had used my one working brain cell, however, I would have remembered that this would only work if I had New Combined Guitar Track set to Input Only Monitoring, which I did not. I think I may have answered my own question, and I am going back down to the studio to try it. But please respond again if you have any additional thoughts, or if you can see that I am still headed down the wrong path. Thanks again for the response!! ![]() |
This is more or less what I though you had done, until you press record then you will not hear input from the Bus.
I should mention that generally posting in the LE forum is best as TDM operates differently to LE in this and many other respects, so to get the right answer then post in the correct forum. I'll bet I was correct, as you realised yourself that you had not pressed the record Button. hope this helps Simon L. |
![]() Quote:
You were right, and my one working brain cell finally made itself useful! I must have not hit the record button the first time, because when I did exactly what I described above this time (and remembered to hit Record before the audio was present), lo and behold, it worked perfectly just like it should have. Sorry for taking up posting space with what amounted to nothing more than "operator error", and thanks again for putting me on the right path! D.J. |
I Imported stereo tracks , but PT reads as 2 L&R Mono tracks ? | Seafoam_Green | Getting Started | 9 | 02-01-2014 09:29 PM |
Only mono and stereo tracks supported, some tracks have been dropped | cowfeet | macOS | 1 | 03-21-2012 07:16 PM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
stereo tracks, mono tracks--thoughts | saeblee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-23-2005 10:45 AM |
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2002 02:31 PM |
