Old 04-18-2008, 01:34 AM
clausiii's Avatar
clausiii clausiii is offline
Default ProFire 2626 or Fast Track Ultra 8R
Hi!
I know this is the LE/WIN forum. As a former LE/WIN user i found here many good information and got help everytime needed. Thanks! Now i switched to Mac (works great btw). But I need sugestions about some general technical issues, which are not Mac-only related. So here it goes:
I´m going to get a new interface. I will need at least 10 Inputs (for drum recording).
So i have two options -> ProFire 2626 or Fast Track Ultra 8R
Which of them is "better" to use?
I will record on an external FW HD. Is there a FW bus overload issue, if i use the Profire and the FW HD daisy chained?
Does anybody know if the Fast Track Ultra 8R allows 10 inputs (8 analog + 2 S/PDIF)? I can´t find any information about that on the M-Audio site...
Are there any issues with USB audio interfaces in comparision to FW ones?
Thanks in advance!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-18-2008, 02:09 AM
mano111 mano111 is offline
Default Re: ProFire 2626 or Fast Track Ultra 8R
definatly go with the FW 2626.
Or 003 coupled with RME octamic or similar (M-audio octane?) will give you 16 analog ins .
I believe the 2626 can handle spdif and alalog at the same time. you will probably need to clock to external spdif though. dependig on what preamp you have that outputs SPDIF this could be good or bad (RME/Apogee = good)
this is a link to the RME and it can work with any ADAT capable interface (other M-audio come to mind). Thair PREs and clock are a very solid choice IMO.
http://www.rme-audio.de/en_products_octamic_2.php
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Differences Between M-Audio ProFire 2626 and Fast Track Ultra robby2161 Pro Tools M-Powered (Mac) 5 12-09-2008 02:14 PM
ProFire 2626 or Fast Track Ultra 8R clausiii Pro Tools M-Powered (Mac) 3 04-19-2008 05:32 PM
ProFire 2626 & Fast Track Ultra Now Qualified With M-Powered Avid Pro Tools M-Powered (Win) 0 03-30-2008 04:20 PM
ProFire 2626 & Fast Track Ultra Now Qualified With M-Powered Avid Pro Tools M-Powered (Mac) 0 03-30-2008 04:15 PM
fast track ultra or profire 2626 gstevenett Pro Tools M-Powered (Mac) 1 01-22-2008 05:25 PM
