Old 01-08-2003, 03:44 PM
xprod77 xprod77 is offline
Default How to play Windows sounds through 001...
I know, I know... this is ill-advised... but unfortunately I don't have the luxury of having 2 computers anymore. So is it possible to play standard windows sounds(Windows media, real player..etc) through the 001? I'm taking a fully online class this semester that requires we be able to play back video lectures on our computer. If anyone has successfully been able to do this WITHOUT any problems or conflicts while recording, please let me know... thanks in advance guys.
-X-
Old 01-08-2003, 03:45 PM
SSRJazz SSRJazz is offline
Default Re: How to play Windows sounds through 001...
install the wavedriver.
-Jeff Schoby
Sacred Soul Records
http://www.sacredsoulrecords.com
Old 01-08-2003, 04:08 PM
Hmmm.. is that the only way? I'm using the ASIO driver to run Reason and you can't have both drivers installed at the same time...great!
Thanks anyway...
X
Old 01-09-2003, 07:49 AM
mike001 mike001 is offline
I'm not sure that this will work but give it a try.
Create a second hardware configuration.
Config one uses ASIO Driver and the other uses the wavedriver. All it would require would be a reboot.
Worth a shot.
System sounds don't play thru Mbox2 Pro in W7 Pro w/ PT 8.0.5 le scott_nikki1216 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2011 02:11 PM
Pro TOols playback is OK, system sounds and other sounds won't play bimple Windows 1 08-24-2011 05:14 PM
Hybrid 1.5.2 will not play all sounds mindmusic Virtual Instruments 2 02-02-2009 10:47 AM
MBox2 Mini - How do I have Windows sounds play through MBOX? Jaison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-19-2008 05:51 PM
Can I play the bundled sampletank sounds... TheLP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-05-2004 06:22 PM
