Old 04-30-2013, 01:54 AM
johannes1 johannes1 is offline
Default pt 10.3.2. crashes when saving | "bus error" in thread Mainthread…
hi there,
when i try to save a session or drag an drop a soundfile from finder to a session i get the following error pop up message:
"bus error" in thread Mainthread at address 0x0
after confirming that message protools 10.3.2 crashes immediately.
(i can send a crashreport if needed)
so i trashed all protools / avid preference & database related filed,
repaired permissions and
uninstall/ reinstall pt 10.3.2
but to no avail.
did i miss something?
thanks for your help,
ciao, johannes
osx 10.7.5
pt 10.3.2 (native)
mbp 2012
(no external soundinterface connected)
Old 04-30-2013, 08:21 AM
Default Re: pt 10.3.2. crashes when saving | "bus error" in thread Mainthread…
… also updating to pt 10.3.4 doesnt change anything. i try to create a
new session but pt crashes. (same "bus error" message)
i forgot to say that i have a:
ssd hd in my mbp
and 2,6 GHz Intel Core i7 (quad)
any ideas how to solve that issue?
EDIT: when installing pt without the avid video engine the crashes happens without any "bus error" popup message (when saving or drag n drop audio).
Old 04-30-2013, 02:38 PM
Exclamation Re: pt 10.3.2. crashes when saving | "bus error" in thread Mainthread…
You don't need the Avid Video Engine installed if you are not using a Mojo or Mojo SDI video peripheral.
Does your session have any ReWire plug-ins?
Old 04-30-2013, 02:52 PM
good to know!
no, its just a raw session with one mono auiotrack in it.
btw. for testing i moved the content of the plugin folder into the unused plugins folder, so i guess the error is not plug-in related…
Old 04-30-2013, 04:13 PM
Question Re: pt 10.3.2. crashes when saving | "bus error" in thread Mainthread…
Do you get the "unexpectedly quit" window in the OS with the details of the crash? If so, could you post that data here or as a txt document somewhere on the Internet (i.e. your public DropBox folder)?
Old 05-01-2013, 12:51 AM
yes i get the message in a os pop up window. here is the crashreport i get when i try to save a session (containing only one audio track) in a folder on my desktop:
https://dl.dropboxusercontent.com/u/...ash_report.rtf
thanks
Old 05-02-2013, 03:11 PM
i also tried to create and save a session on a external hd which for me results in pt crashing. anybody who had a similar problems and found a solution?
maybe i forgot to say: after the update from pt 9 to 10 and from lion 10.7.2 to 10.7.5 the described "bus error" appears. after reinstall pt without Avid Video Engine the error no more appears but pt is still crashing. i don´t get it.
would it help to reinstall lion 10.7.5 on my machine?
EDIT: i now also created an admin account on my mac and tried to run pt from there… still with same outcome: pt crashes.
please give me hand with that. thanks
Old 05-02-2013, 04:35 PM
i finally made it!
i did it the john rambo way. i killed all files and folders with word "avid",
"pro tools" and "digidesign" i found on my hd. than reinstall and all worked fine.
Old 05-02-2013, 06:28 PM
Arrow Re: pt 10.3.2. crashes when saving | "bus error" in thread Mainthread…
Originally Posted by johannes1 View Post
That was definitely a Pro Tools crash while saving a file. Glad to read that you have your problem resolved.
"Bus error" in thread "MainThread" at address 0x0 Tronic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 62 12-27-2012 10:21 AM
"Bus error" in thread "MainThread", at address 0x0 polbb macOS 1 10-01-2012 06:50 AM
"Bus error" in thread "MainThread", at address 0x0 mnicoli macOS 2 04-10-2012 07:42 PM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
"Bus error" in thread "MainThread", at address 0x0 mnicoli Pro Tools 9 1 03-30-2011 08:08 PM
