Computer not recognizing MBox2 Mini; USB light on
Hi all,
I'm very new to this so I hope this isn't a stupid question. I just installed Pro Tools LE 7.3. I can get as far as the loading screen but then I get a pop-up that says: "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready." So at this point, I plug my MBox2 Mini into the USB port of my computer and click OK. BUT for whatever reason, the pop-up box won't go away and keeps coming back up and I can't get past this point. The USB light on the MBox is on. I did a little poking around on some troubleshooting threads and have seen similar issues with the USB light NOT coming on, but mine IS on, so I'm not sure that it's the same issue. Anybody have any ideas? If more info might be needed about my specific PC set-up, please let me know and I'll be happy to provide. I truly appreciate any and all feedback! Chris |
Re: Computer not recognizing MBox2 Mini; USB light on
Now could possibly give us LESS info? Start here:
Help us help you - what you need to know before posting! and post a Sandra report. What happens if you connect the Mbox BEFORE you try to open Pro Tools. Did you install according to the instructions in the Getting Started Guide, or just plug in the Mbox and let Windows install drivers automatically?(believe me, it matters). Post your Sandra so we can have a chance of offering advice.
We're going to need some more information to be able to help you.
Will you please read Help us help you - what you need to know before posting and follow the instructions there? It will definitely help us.. help you... We don't even know which version of Windows you are using.
Haha...sorry guys. I DID say I was new at this!
The Sandra report is below. Albee, I basically just loaded the CD and installed the software, so I suppose if there is a particular way to approach the installation, that might be a good place for me to start over. Even so, if anything in this report catches your eye as a potential road block or show stopper, please let me know. Thanks for the help guys! SiSoftware Sandra Computer Model : Dell Dell DXP051 Workgroup : MSHOME Host Name : chris-c3d63d9d4 User : Chris Processor Model : Intel(R) Pentium(R) D CPU 2.80GHz Speed : 2.8GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 1MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : Dell 0YC523 BIOS : Dell A07 01/08/2007 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 1.5GB DIMM DDR2 Chipset Model : Dell 82945G/GZ/P/PL Processor to I/O Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 1.5GB DIMM DDR2 Memory Bus Speed : 2x 267MHz (534MHz) Memory Module(s) Memory Module : Infineon (Siemens) 64T32000HU37A 256MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 3-16-4-2) Memory Module : (Bad Id) 512MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Infineon (Siemens) 64T32000HU37A 256MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 3-16-4-2) Memory Module : (Bad Id) 512MB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Video System Video Adapter : RADEON Radeon X300/X550/X1050 Series (4 PS2.0, 2 VS2.0 324MHz, PCIe 1.00 x16) Storage Devices WDC WD2500JS-75NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 233GB (C:) Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) : 466GB (F:) WD 2500JS External 250GB (FireWire/1394, NCQ) : 233GB (G:) Logical Storage Devices Hard Disk (C:) : 233GB (NTFS) @ WDC WD2500JS-75NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) The Rock (F:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) My Book (G:) : 233GB (FAT32) @ WD 2500JS External 250GB (FireWire/1394, NCQ) Optical Drive (D:) : N/A Pro Tools LE (E:) : 2GB (CDFS) Optical Drive (H:) : N/A Peripherals LPC Hub Controller 1 : Intel 82801GH (ICH7DH) LPC Interface Controller LPC Legacy Controller 1 : SMSC SCH5504-NS Audio Device : Dell 82801G (ICH7) High Definition Audio Audio Codec : Sigmatel 7680h Serial Port(s) : 1 Disk Controller : Dell 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : Dell 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 2 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 3 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 4 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 5 : Dell 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : TI TSB82AA2 IEEE-1394b Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Intel(R) PRO/1000 PL Network Connection - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
***I just recalled you are working 7.3 here, so you won't have the PT8 uninstaller. Search the DUC for PTNuke. Its a great little utility for cleaning out any Pro Tools software/drivers so you can attempt a clean install. I hope I am wrong about the problems above. Got my fingers crossed for ya
MacBook won't recognize mbox2 mini. No light on and drivers installed! | Afwfjustin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 07-25-2012 03:31 AM |
Macbook Pro not recognizing Mbox2 | TheMeep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2012 01:52 AM |
Just bought a Mbox 2 mini, usb light doesnt light up/installation stops progressing? | DjRybe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-27-2009 05:55 PM |
New Computer Not Recognizing Plug-Ins | bigcow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-15-2008 02:41 PM |
im frustrated: why isnt my computer recognizing mbox2? | alex101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-03-2007 11:38 AM |
