PT LE 7.0 and Video Cards...does it matter?
Does PTLE 7.0 performance vary depending on the video card used in a computer?
I've decided to build a PT computer, kind of taking the Allenstein route, and using an AMD Dual-Core processor, SLI motherboard, 4GB ram, and 10000 RPM hard drives. XP Pro. Will my choice in video card affect PT's performance? I have a GeForce 6600GTOC now, because I have dual DVI displays. Should I get a more-powerful card? Truthfully, I haven't noticed a difference between the 6600GTOC I have now, and the GeForce 5200 that came with my computer. As you can tell, I'm pretty green when it comes to computer stuff. That said, I'd rather buy once and cry once, than have to keep replacing stuff. I want this computer to work, out of the gate, and I don't want to mess with it ever. Thanks for your advice, Nick
2-Opteron 265/TYAN S2877/4GB WD Raptor Drives/Dell Quad Displays Dual 7600GT Video/XP Pro SP2/PT7.3.1 Digi 002R |
Re: PT LE 7.0 and Video Cards...does it matter?
yes and no.
the video card shouldnt directly affect PT performance, however in reality video cards/drivers do have a small effect on the overall system. (this is understandable if you know how video drivers work under windows) i got a minor performance boost when moving from an FX5200 to a RADEON 9600, and didnt have to deal with any of the drivers causing problems in PT that i had for awhile with the 5200. in the end if the card is working fine stick with it as any difference will be very minor. compatability/stability come first and there is no need to fix something is isnt broken. |
Do RADEON cards have better drivers than NVIDIA cards? Nick
--joe |
Nick
nVidia update their drivers regularly, usualy they get things right but sometimes they dont. when i had the FX5200 for awhile i wasnt able to use low buffer sizes as any live tracks would cut out every second or so. once i updated the driver again it was fine. best advise is to go with a card that others are using problem free. |
Okay, I can speak with some knowledge on this issue.
I had a Matrox G550 that refused to work well on an nForce2 motherboard. Swapping to an ATI Radeon 9200 (or was it a 9600?) fixed that. On my current system, I went with a mega fast screamer computer. Asus A8N-SLi Premimum, Athlon 64 4200 X2, etc. Went with a Sapphire ATI Radeon X550 PCI-E video card... but if you install the AMD CPU driver instead of just using the "stock" MS one that installs with Win XP Pro, and if you install the "extra" software for that video card (ATI Catalyst), you WILL have issues with PT LE - no click track plug in functionality, and MIDI is a mess overall, and doesn't work properly. At least with this system *I* had those issues. A reinstall of Win XP did not cure the problems, and neither did rolling back the drivers, un-installing the extra ATI software (using the basic ATI vid driver is okay - just don't install anything else) and manually editing the registry to remove all traces... the only way to get functional MIDI use from PT LE was to completely reformat the C drive and start all over again withy a clean install, and skip installation of the problem drivers / software. Major pain in the butt. But not really Digidesign's problem IMO (and for the record, they did their best to help me track things down ), and maybe not ATI's or AMD's either... but frustrating nevertheless. Yes, the video card you pick, and ALL other hardware and software CAN make a difference. However, you don't need a super high-performance video card for use with PT LE. No 3D accelerator or anything like that. A basic AGP or PCI-E card should work fine, but then again, sometimes there can be specific hardware compat. issues for whatever reason - like with my old G550 and the nForce2 chipset mobo. I personally like cars with 64 - 128 MB of memory on them as a minimum, and a dual display capability. Dual displays in PT LE rock. Edit window on one, mix window on the other. But I digress... the only other video issue I've had with PT LE has been with the Smack! plug-in. The metering on that doesn't work properly with a display setting of 16 bits. At 32 bits, it works fine.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Nick
I want to use the ASUS SLI motherboard, and even kicked around the idea of getting the two video cards, and run them SLI. But I'm a bit confused about SLI. Does anyone know if you can use two displays with it? What I read said that you plug one display into one card...but what if that "one card" has dual DVI, for instance? Could you use both DVI outputs?
Nick
Best Video Card 512 or 1 gig. Does it matter? | scottmach | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-27-2010 09:46 PM |
video cards | scatta | Pro Tools TDM Systems (Win) | 1 | 05-18-2007 07:46 PM |
Video Cards | logicprobe | Pro Tools TDM Systems (Win) | 11 | 09-28-2004 08:33 AM |
OT.......Video Cards | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-27-2002 12:47 AM |
Video Card - Does it matter? | VividMax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-12-2001 10:13 PM |
