Re: Best EQ Plugin(s)
To add my 2 cents.
Itīs always the question of use...has it to be really surgical or more coloring? Just because it always does something to the material. EQ plug ins even can de-color material which in most cases you do not want. Probably the perfect pair in reference to the question above. As for the initial question of the OP like all the others here I have got tons of EQ plug ins over the years (most of the Waves, MCDSP, UAD, PA etc and way more I would/do actually need...) but if I had to choose to only keep one single EQ plug in, believe it or not, I would go for this one. https://hofa-plugins.de/en/plugins/iq-eq/ Just because this is one of the very rare EQ plug ins which combines being really surgical and still adding a slight shimmer/color to the material if being used in the 4x+ oversampled mode. In the live (zero latency)+the basic 2x oversampled mode itīs more a surgical one. Further you get a very useful and very well working dynamic section you can turn on/off per band and tweak very well all within this plug in. Itīs not the most affordable EQ plug in ($135.- for registered audiodeluxe users) but itīs definitely worth the price in the long run as you can use the HOFA IQ-EQ for almost everything on most tracks in your session. Once you got used to this plug in you donīt want to miss it anymore. Useable for single tracks, busses and pretty useful on the master as well. Still kinda underrated EQ imo. https://www.audiodeluxe.com/products/hofa-iq-eq Btw made by german studio guys for personal usage only originally the plug ins from HOFA have become quite popular in Europe and they always offer a 14 days fully functional demo version and two licenses (machine or/and USB) for every plug in finally. ...Yeah, I forgot to mention that I have nothing to do with HOFA personally. Just being a fan of some of their plug ins. Last edited by VRW; 02-28-2017 at 12:52 AM. |
I've only recently purchased/switched to EQuilibrium this calendar year, and on the project I'm working on now I've completely removed ALL instances of fabfilter Q2 replacing that with EQuilibrium in the mix, and am using EQuilibrium in the Mastering process as well. The leap in clarity and punch as a result of the replacement of Q2 with EQuilibrium I would not have believed had I not experienced it myself. I continue to use EQuilibrium along with Kush's Clariphonic, Electra, UAD's Chandler, Neve 1073 MkII, Pultecs, channel strips (Neve 88RS & API Vision), Plugin Alliance's bx_console coupled with Kush's Omegas and real Neve 1073s, API 550As and Summit EQs. If you're looking for "one EQ to rule them all" ... I'd highly recommend trying DMGs EQuilibrium. I'm blown away! (I have no affiliation with DMG Audio, am not a paid actor - just a new fan of the man and his products)
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
Sonnox actually has four different eq:s in one plugin, plus fifth if you have the dsp license and have bought the gml option
I used the MDW on everything, but then 2 years ago MDW got hit by an fault in update... spikes al over the place... unworkable.
So after some tests I went to SSL X-EQ, best EQ I've used. Now the MDW bug seems to be fixed and now I switch between the 2
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11 16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1 MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch + madi baseunit + optical SFP 1300nm MOM v.1.0.1.4 by DAD Genelec 1237A Sam, Avantone active mixcubes LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro Furman P1400 AR E Power conditioner Live-rack: 1x HD Native TB, 4x 192 I/O (64ch AD) 8x Yamaha HA-8 micpre, Rosendahl mif4, Genelec 1031A, Presonus Monitor Station |
Just an FYI ...
#16
A good Pultec-style eq is a must have for the toolbox. Believe it or not I kind of like the iK ones. For all the hype about them or maybe it's the implementation that I use (the NI one) but I have trouble getting a good sound out of a Massive Passive eq. Three others I use but they're kind of limited are the Waves Abbey Roads RS56, Redd 37/51 and TG12345. Yes I know the latter two are 'channel strips' but I use them when I need that 'British' sound. I almost forgot - the Tilt EQ from HOFA. Freebie unless you want the dynamics part. Sort of a one knob tone control with tweakable center freq. and hpf/lpf if needed. |
#17
FabFilter, EQ III and Waves Puigtech are all over every mix I do. Really, I could do everything with EQ III and the cheapo Bomb Factory Pultec, but FF is just too nice(great display) and the Puigtech is silky smooth(BF Pultec is a little gritty, which sometimes is wanted)
#18
#19
There's more to an eq. than just the curve! EQuilibrium is very good as is Sonnox, especially the GML version. I still use Q 10 and if I want color. I've also been known to drop in a character plug-in such as Puigtech and leave it flat.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#20
I used fabfilter Q2 as a surgical EQ because it does have a great UX. That's it best feature, IMHO. However, it is very limited in terms of its processing options. You have 1. Zero Latency 2. Natural Phase and 3. Linrae Phase (with 5 preset buffer size options on this choice only). Because of this relatively few choices and I believe only IIR processing, it has (IMHO) a hashy cloudy sound that when multiplied cumulatively, really takes the punch and clarity away. It's not subtle. Conversely, DMG Audio's Equilibrium has many processing options, starting with IIR and FIR. I've been using it's FIR options, and a combination of it's Zero Latency Analogue Kaiser with an 8K buffer window and 8x Impulse padding and it's Free (phase free) processing choices. I have way more control, and because of that (and it's variety) I can reduce the cumulative effects (because I use a variety of processing options) and DMGs FIR processing appears to be friendlier with transients (hence the punch). In terms of your curve question - my experiment was to replicate the fabfilter created curves exactly. When I moved into DMG's FIR modes I left fabfilter in the dust. I can't go back. I hear fabfilter now ... and other then using it as a deliberate effect, I won't touch it. That's my opinion and what works for me. YMMV Now not everyone will hear what I hear, nor care. It's personal choice. I like big, bold, clear and aggressive mixes - so a cloudy transient stomping EQ goes against what I consider good. Try it for yourself. I would not have believed this had I not spent some time with Equilibrium. Use your idea of replicating the same curve, try the different modes and see if you don't find one you like better. If you don't, worst case you lost a couple hours. If you do (as I did), it will drastically change your sound. Clear and Punchy. Good luck!
Trim DSP plugin uses CPU power when inserted before a Native plugin? | BEN6732 | Pro Tools HDX & HD Native Systems (Mac) | 11 | 03-30-2016 03:36 PM |
Anyone else have issues with Plugin Alliance Rtas plugin presets? | realizment | Windows | 0 | 04-01-2015 05:04 AM |
Mega plugin deals!! Slate, plugin alliance etc | crizdee | AAX Plug-ins | 3 | 02-06-2014 11:03 AM |
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 | klyg | Artist Series | 2 | 02-29-2012 10:50 PM |
Vocal plugin needed to change voice, what is the best plugin | Logicdance | Digidesign Hardware & Software | 0 | 03-13-2007 04:26 AM |
