Which is a good Mac cdrw burner ?
That's what i'm looking for to burn from my B/W G3
Old one's defective Having these lovely Granite scsi cables i would continue to use them , not usb , or maybe firewire ? Some advice ? Marc |
Re: Which is a good Mac cdrw burner ?
can't go too wrong with Yamaha IMHO
[img]images/icons/smile.gif[/img] |
And what about Lacie or Plextor (or is that only PC?)
...I went with the Firewire drive to keep the SCSI bus short. ...
Yeah, that's a good idea Barnabas, just a bit anxious, scsi works (with $$$ Granite Cables) never used firewire- Sorry, that's a lie - a friend brought his rubber LaCie PocketDrive HD & that went flawlessly It's gonna be firewire i guess Thanks guys |
My CDR on my B/W G3 went bad too, so I just got the Glyph WildFire CDR that connects via Firewire. It's not working for me yet, but Glyph and I are ironing out the bugs. It works great on my G4, but my PT is on the G3. It uses a Plextor drive.
I went with the Firewire drive to keep the SCSI bus short. I think if I had OS 9 on the G3 instead of 8.6 it might work already.
www.barnabas.com Barnabas MultiMedia |
If it's compatable, try the Glyph firewire drive called "Wildfire" It's a plextor drive in a Glyph box, but Glyph has great tech support and customer service. Mine's an 8X, but maybe they're making them faster now. 8X has been good enough for me though.
www.glyphtech.com Good luck! [img]images/icons/smile.gif[/img] |
[img]images/icons/blush.gif[/img] duh, I guess I should've read all the way through Barnabas' post before I thought I had the answer to save the day!!
[img]images/icons/grin.gif[/img] |
LaCie 24x write firewire.. Its wonderful.. Simple Plug N Play...
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Anyone uses a firewire cdrw burner with a B/W G3 working well?
Or should i stick to SCSI ? |
My Glyph Wildfire is a 16x10x40 CDRW. It has the Plextor PX-W1610tA drive. As I said, it works great on my G4, but not on the B/W G3 running OS 8.6. I did have to upgrade the firewire extensions, but it still doesn't work. Glyph says it will work on any G3 or G4. Glyph and I are exchanging e-mails trying to get it to work.
I've never used the firewire ports on the G3. Is there some way to test them?
A good CD burner and 2-ch AD/DA converter? | Naagzh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-23-2004 06:53 PM |
Good Deal on DVD Burner | Sugarnutz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-14-2003 03:49 AM |
Firewire cdrw burner on B/W G3 ? Yes or No? | Marc Cooreman | General Discussion | 2 | 12-10-2001 09:10 AM |
Help Finding Good CD Burner Buy... | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-10-2000 06:04 PM |
Can someone recomend a good C.D burner? | jag | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 03-11-2000 07:23 AM |
