Old 07-27-2021, 03:30 AM
ShadeTek ShadeTek is offline
Default Izotope RX7 2021.6 motorboating issue.
Since updating one Z440 system to W10/20H1 to install PT2021.6, Izotope plugin RX7 now motorboats the audio when previewing it in the stand alone app. Completely rebuilt the system with a fresh OS and RX 7 worked fine until PT 2021.6 was installed. Anyone else have this issue?
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock.
Old 07-27-2021, 04:10 AM
Default Re: Izotope RX7 2021.6 motorboating issue.
Installing PT 2021.6 won't affect the standalone version of rx7. Been using both PT 2021.6 and rX7 standalone no problem on the Mac in my profile. If you're having issues it's not with the combo programs - you have other issues going on.
Jack
QAPLA!
Old 07-27-2021, 06:34 AM
....I tried a trial version of RX8 and it motorboats too for the record. All other programs that use windows audio, IE Soundminer, Chrome all media players work fine. Just RX 7+8 that fail immediately after installing PT 2021.6 on two identical systems.
Old 07-27-2021, 09:30 AM
Like I said - installing PT 2021.6 won't affect rX7. You have something else going on with your system. Make sure you're not trying to share your audio interface between Windows and rX or PT.
Jack
QAPLA!
Old 07-27-2021, 11:55 AM
s.d. finley s.d. finley is offline
RX7 in standalone and RX Monitor with PT 2021.6 working fine on MBP 2020 (macintel) with Catalina.
sdf
www.sugarhillstudios713.com
Old 07-29-2021, 08:16 AM
..and here is a solution. Why it suddenly stopped working...?
https://support.izotope.com/hc/en-us...-How-to-Use-It
Old 07-29-2021, 08:38 AM
Good that you found a solution; that it happened when you updated to PT 2021.6 is pure coincidence. As I wrote before Windows doesn't do well with sharing audio I/O between different programs at the same time. I'm guessing you were trying to use rX outside of PT with PT running at the same time, right?
Jack
QAPLA!
HTML code is On
weird mouse issue in 2021.6 paul_g Pro Tools 0 06-26-2021 02:46 PM
2021.3.0 Install Issue piby Windows 3 04-01-2021 08:00 AM
PT 2021.3 Install Issue stratpicker Pro Tools 3 03-28-2021 08:08 PM
2021 & iZotope Jazzbass56 Pro Tools 8 03-27-2021 07:03 AM
Come on! 2021 already. Just issue what’s right. DetroitT Pro Tools 2020 0 03-05-2021 05:35 PM
