Old 04-02-2019, 12:41 PM
ihate100bees ihate100bees is offline
Default How to retrieve project from Avid Cloud?
I uploaded a project for collaboration. Then I worked further on the project and saved it... and I thought I was working on the version that was on my drive, but when I tried to re-load the project my my hard drive, I noticed the new work was not there. It is only on the version I had uploaded for collaboration to Avid Cloud. I would like to retrieve the project from the cloud back and save it over the original that is on my drive. How would you do this? No collaboration has been done.
Thanks
Old 04-02-2019, 02:22 PM
Default Re: How to retrieve project from Avid Cloud?
Open the Project and do a Save Copy In ?
Old 04-02-2019, 04:20 PM
Thanks for replying. I did "Save a Copy in..." of the project but it is still a copy that is stored on the cloud with the collaborated file, and not on my drive, as it has that cloud symbol too.
Old 04-02-2019, 06:54 PM
amagras amagras is offline
Go to the location where you supposedly stored the session and see if it's there. Open that and if it works you are safe to delete the project from the cloud.
amagrasmusic.com
Old 04-02-2019, 08:02 PM
No, the updated tracks are not there. They are only in the Cloud.
Thanks
Old 04-02-2019, 11:01 PM
This is not rocket science.
Again. You do a Save Copy In.
Did you look carefully at what you are doing here? You have to select the session format in the Save Copy In dialog panel. If you select a **Session** format you get a session, if you select **Project** you get a Cloud Project. It's the most natural extension of how Pro Tools has worked before.
Old 04-03-2019, 07:21 AM
Yeah I get it that this is not rocket science. Let's not go there. Anyways, I told you, I didn't save in and it still has the copy that has the cloud emblem. I will try saving it as a session and then check my drives. So far, the new tracks that I did on the project or not in the project that is on my drive. Thanks for this new information and I will try it and let you know if it works.
Old 04-03-2019, 07:41 AM
Session = hard drive
Project = cloud
amagrasmusic.com
Old 04-03-2019, 09:05 AM
Thanks! Very clear answer. I will try it.
Old 04-03-2019, 02:42 PM
Thanks guys! Saving to session worked, and the files are now on my local Drive. 👍👍
PT Cloud Collaboration: Can't invite anyone to project hannuala Pro Tools 2018 18 08-22-2019 09:33 AM
Protools First Cloud project headlap Pro Tools 12 2 12-11-2018 12:03 PM
Error Loading Cloud Project jazzyhacker Pro Tools | Intro Discussion 7 10-19-2016 04:20 PM
Always 99% cloud even an empty project ... babaorum Pro Tools 2018 17 07-19-2016 09:18 AM
