Old 11-02-2016, 02:54 AM
Fuzzyc Fuzzyc is offline
Default Editor won't load if Pro Tools is running
Just purchased an Eleven Rack and everything is working fine with one exception. The editor will not load if Pro Tools is running. So if I accidentally close it out (like a plugin) or forget to load it before Pro Tools, then I have to close down my session before I can get the editor to load.
I'm running version 2.0.1 (build 0.1.5.7) of the Editor and using Pro Tools 12.6. I'm on Windows 10 64-bit. Is this is known bug that I just need to live with or is there a solution to this?
Thanks!
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2023
Focal CMS 65 Monitors
Avantones
Old 11-02-2016, 05:45 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Editor won't load if Pro Tools is running
Is your 11rack setup to be the default playback device in the control panel?
Sounds like that might be the issue
Daniel
Old 11-02-2016, 02:52 PM
Benoni's Avatar
Benoni Benoni is offline
No, that should not be happening. I tested this on Windows 10 using Pro Tools 12.6 and I was able to open the Editor after Pro Tools was open.
I would suggest you uninstall the Editor and re-install it. And/or you may want to do this procedure
You should be able to open the Editor from within Pro Tools or by using the launch shortcut on the desktop or Start Menu.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-02-2016, 06:05 PM
jjnssn jjnssn is offline
Curious. Do you have the show dashboard window when pro tools starts unchecked in the display preference page? If yes, try turning it on and restarting pro tools and see if you can then start the editor.
Old 11-03-2016, 05:08 AM
MADIrouting - I checked and "Show dashboard when pro tools starts" was already checked.
Thanks for replying...
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 11-03-2016, 05:15 AM
I uninstalled the Editor and reinstalled it. I also did the trick of deleting the Eleven Rack Editor folder per Benon's video I had already done that a couple of times however.
I still can't load the editor if Pro Tools is running. If I load it by clicking on the program in my tool tray I just get a white/blank window. When I try to load it via the Window menu from within Pro Tools nothing happens at all. If I exit Pro Tools it loads fine.
Thanks for trying to help...
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 11-03-2016, 11:35 AM
Benoni's Avatar
Do you have Quicktime installed? If not, try installing it.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-04-2016, 04:52 AM
Yep. I've got Quicktime installed. Puzzling, huh?
Thanks
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 11-04-2016, 01:04 PM
Benoni's Avatar
Thanks
Open the Editor. Then Launch Pro Tools.
Press the Editor button in the Mini Window a few times. This should show and hide the Editor. If that is working, close the Editor by clicking the 'X'.
Now click the Editor icon in the Mini Window again. Does it open?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-06-2016, 03:37 AM
Clicking on the editor button in the mini window doesn't show and hide the editor. The editor icon in the mini window is greyed out. It's the only button in the mini window that won't do anything.
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
AES / EBU not passing audio, graphics in editor won't load... DrFord Eleven Rack 1 12-16-2014 05:27 AM
Pro Tools 10 not load plugins,freezing load.HELP javierboz Windows 2 11-08-2012 04:25 AM
Editor crashing Pro Tools 8LE dcrissinger Eleven Rack 4 12-19-2011 06:17 PM
Screen Flickers with Pro Tools 8.4 & Melodyne Editor running protoolsuserman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-28-2010 06:04 PM
Running Pro Tools LE 8 on XP and running 2 monitors JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-31-2010 07:38 PM
