Old 07-21-2021, 06:00 AM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Default S1 shows HIDDEN+INACTIVE tracks within folder ?
S1 still shows spilled tracks within a folder although the folder and contents is NOT showing in PT (=right clicked on folder+active tracks and selected HIDE AND MAKE INACTIVE).
Seems like if the folder was open when I chose H+MI, the contained tracks will still show on the S1.
But if I close the active folder first in PT and then select H+MI, the tracks will be removed from the S1 as well (as should be).
I thought this was because of the EuControl (2021.6.0.181) setting in GENERAL: SHOW CLOSED FOLDER MEMBERS IN SPILL (checked). But even if I uncheck it, the folder members still show.
Old 07-22-2021, 09:32 AM
EddieJones's Avatar
Default Re: S1 shows HIDDEN+INACTIVE tracks within folder ?
What version of PT are you on....It rings a bell and i thought it was fixed.
Old 07-22-2021, 10:07 AM
Hi Eddie ! PT Ultimate 2021.6.0, EuControl 2021.6.0.181, Mac os 10.14.6
Old 07-22-2021, 10:12 AM
EddieJones's Avatar
If you close and open the folder does it fix it? If not open and close the session?
Old 07-22-2021, 10:20 AM
EddieJones's Avatar
I just tested this (on my Windows) and it works OK.
Hidden and Inactive tracks in Output Path selector Sonopolis Pro Tools 2020 2 02-21-2021 11:42 AM
After update hidden and inactive tracks show on s1\dock\control app ramonetl Avid S1, S3, Dock and Control App 7 06-26-2020 10:29 AM
Layouts And Deleted/Inactive/Hidden Tracks Lynn Gräber Avid S1, S3, Dock and Control App 2 04-18-2020 08:20 AM
Reading Track Overviews on inactive and hidden tracks russ russell Pro Tools TDM Systems (Mac) 1 05-04-2011 06:23 AM
Making Multiple Hidden Tracks Inactive? stuseattle Pro Tools TDM Systems (Mac) 2 08-13-2010 12:01 PM
