Old 02-02-2016, 02:20 PM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
Default Help! Major Midi problem after going 10.3.10
Hi, folks
I have tried uninstalling, reinstalling, examining audiomidi setup but after installing 10.3.10 Hd, Pro Tools MIDI has become very buggy!
I have a miditime piece AV Usb connected to an Alesis D4 (ports1), JV1010 (ports2), MDC1 (ports3), 02R96 (ports6) and a main controller Fantom XA (ports8).
No matter what I do, midi data does not enter Pro Tools anymore. I have already changed cables and also tested the midi out of this keyboard going directly to any sound module.
Also, If I lower one of the faders all others go up and down, even if there are no groups created (!). Sometimes same patch plays on multiple midi tracks!
Until december everything was fine with 10.3.8 HD.
I tried uninstalling 10.3.10 and reinstalling 10.3.8 and it does not open up. So I reinstalled 10.3.10 again.
Any help about this midi thing? I also changed usb connectors and redeclared sound modules.
THis midi setup had been fine for several years . Curiously when I opened it, MTV AV usb was duplicated, with a blank unit right at its side. I deleted it.
Thanks for any help.
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Old 02-02-2016, 05:55 PM
Default Re: Help! Major Midi problem after going 10.3.10
bump
Alécio Costa Studio
www.aleciocosta.com
Old 02-03-2016, 09:50 AM
no one from Avid to give a guiding light?
User since 1999 here, never saw this.
Alécio Costa Studio
www.aleciocosta.com
Old 02-03-2016, 09:56 AM
Trying this:
USB MIDI Drivers and ClockWorks for Mac OS X
This installer package (version 1.6.49190) installs updated Mac OS X drivers for all MOTU USB MIDI interfaces, including the USB FastLane, micro lite, MIDI express 128, micro express, MIDI Express XT, and MIDI Timepiece AV. Includes a completely rewritten, Intel-native version of ClockWorks for the MIDI Timepiece AV, MIDI Express XT, micro express and Digital Timepiece. Mac OS X 10.5.8 or later is recommended. Supports Mac OS X 10.8 (Mountain Lion).
Alécio Costa Studio
www.aleciocosta.com
Old 02-03-2016, 11:44 AM
crizdee's Avatar
crizdee crizdee is offline
Have you trashed the AMS prefs, rebooted and re-installed the software driver for the timepiece?
As long as the driver is compatible with your OS and it all works in the AMS then PT should work fine with it.
If you want to revert back to an earlier version of PT, then make sure you use the uninstaller that came with that version you have installed? or HAD installed. if you had 10.3.8 installed then you need to use 10.3.8 uninstaller before you install another version of PT etc
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-03-2016, 01:47 PM
Hi, Cris
Thanks for your concerns!
a) when you say trash AMS preferences, do you mean the portion labeled as com.apple.audio.AUDIOMIDISETUP.list of the Pro Tools Pref and data base helper? I use an old version since 8.1.1
If not where do I find this AMS preferences?
b) I installed the updated 2011 MTV AV USB drivers.
c) I uninstalled 10.3.10 and installed 10.3.8 and it just would not reboot. Then, I reinstalled 10.3.10. I will look carefully at the uninstallers tip
Alécio Costa Studio
www.aleciocosta.com
Old 02-04-2016, 11:17 AM
Default Finally, I found the source of the problem!
After trashing preferences, reboots, re-installations of 10.3.8 and 10.3.10 with no success I decidec to connect a friend´s USB Motu Xpress Midi interface and it did go fine.
Then, I had the idea to reset my MTP AB USB.
I just had to do panic + power on and everything went back to normal!
Believe me...for a while, it is pretty fine again!
Thanks
Alécio Costa Studio
www.aleciocosta.com
Major PT 11.02 problem Challabong macOS 1 10-23-2013 04:41 AM
Major problem Empireofthesun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-23-2010 05:58 PM
Major problem....help, please!?!?!? gruntmaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-13-2009 04:14 PM
Major Problem 6.8r2 shea Pro Tools M-Powered (Mac) 3 07-05-2006 04:23 PM
Major problem! EricFuller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-16-2004 12:09 PM
