Old 03-04-2009, 02:30 PM
MdotCash MdotCash is offline
Default Automation with Midi??
Is there a way to record Plug-in automation to pro tools from a midi keyboard using a CC#?? Im using a Korg Triton Extreme as a controller...tryin to automate the Fuzz-Wah Plugin.
Old 03-04-2009, 05:58 PM
Default Re: Automation with Midi??
Assign the plug-in parameter to CC# what ever and use Pro Tools Automation to write.
filosofem
Old 03-04-2009, 09:09 PM
Appreciate the help, but how do i assign the "pedal'"parameter to a midi cc#.???
Old 03-04-2009, 09:21 PM
Does the plug-in support 'MIDI Learn' or have a MIDI CC routing page? If not you will have to use CC Automation.
filosofem
Old 03-05-2009, 08:29 AM
Its the A.I.R Fuzz-Wah Plugin, I dont see any midi routing page for this plugin.
Old 03-05-2009, 05:50 PM
You will then need a supported Control Surface.
filosofem
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Convert MIDI automation to audio automation jnash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2010 03:28 PM
Midi Automation on LE 8 lideeq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-30-2009 02:33 AM
Midi CC automation GeckoMusic Pro Tools M-Powered (Win) 2 10-02-2008 05:28 PM
Midi volume automation when there was none smlworld MIDI 0 06-07-2007 06:03 AM
