Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-24-2001, 03:42 PM
Peter Duemmler Peter Duemmler is offline
Default Control24 fader resolution?
Any info on that?
And will it be "open" to support other apps like Logic Audio?
Peter
[This message has been edited by Peter Duemmler (edited January 24, 2001).]
http://www.merlinsound.de
Old 01-24-2001, 04:14 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: Control24 fader resolution?
Control24 being an ethernet-controller like its "bigger" brother, this seems doubtfull at the least.
Digi, if C24 is going to be "open" for App's like Logic, can we suppose that PC will follow ????
Chris Lambrechts
digi, is this one OK ???
(no I'm not a member or employee there, I don't even know them but they try to add their 2 cents ............ and I support them doing that)
http://www.copyrightcontrol.com/Clients.asp
Chris Lambrechts
Applications Specialist- Live Sound
Old 01-24-2001, 05:53 PM
There´s no answer yet, but assuming you´re right it would just p**s me off...
All those companies coming out with hardware controllers for special programs (ProControl for ProTools, Houston for Nuendo/Cubase, Mackie has announced a controller for Logic)...
It seems that way I´ll be "forced" to buy a SAC2K (though it only has 256 steps resolution for faders), cause it works with more apps - and I WANT to use at least Logic AND ProTools.
Peter
Old 01-24-2001, 08:39 PM
KymataDigital KymataDigital is offline
For ProControl or Control|24 to be compatible with Logic, Emagic would have to adapt the 10BT protocol that Digi uses for communication with their mixers. I can't see Emagic doing this, as they are mostly concentrating on equalling the features in Cubase/Nuendo. And, Logic's automation is based on MIDI resolution...not sample resolution.
Maybe this will change with mLAN?
/paul
[This message has been edited by KymataDigital (edited January 24, 2001).]
Old 01-24-2001, 09:59 PM
uno1234 uno1234 is offline
digi, tell us what the fader resolution is! no one has a clue.
Old 01-25-2001, 07:11 AM
gk gk is offline
Hi all,
The faders on Control|24 have a resolution of 1,024 steps, just like ProControl. Unlike ProControl, however, the faders are not digital encoders. We use an analog fader from Alps and derive the resolution electronically, with excellent accuracy. The faders have proven to be quite a reliable solution.
I hope this helps. We will be posting a Control|24 data sheet shortly to help answer your question.
Thanks!
-Gannon Kashiwa
Control Surfaces Product Manager
Digidesign
Old 01-25-2001, 07:16 AM
Thanks gk!
Old 01-25-2001, 03:07 PM
Wow!
Anybody interested in a recently refurbished TAC Magnum 36/24/8/2PB? It seems I have to get some money and blank space...
Peter
Old 01-26-2001, 12:38 AM
WOW, so now in this price range category (under let's say 25k $), there are 3 mixers / surfaces which have 1024 resolution :
ProControl
Sony DMX-1000
Control24
Anyone know of any others ??????
btw, Gannon, you say with excelent accuracy, what does this mean, do the electronically controled faders get to get the maximum out of all 1024 steps, like in the PC or the DMX, or do they skip a step from time to time ???? ....... curious to see if it will be on that data sheet.
Chris Lambrechts
[This message has been edited by Chris Lambrechts (edited January 25, 2001).]
Chris Lambrechts
Fader Callibration for Control24 tim carter ICON & C|24 3 05-11-2010 10:19 AM
Command 8 fader resolution lululu ProControl, Control|24, Command|8 7 10-22-2009 02:37 AM
What is the fader resolution on the 003 factory? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-30-2007 09:39 AM
Fader resolution in PT johnnyv Pro Tools TDM Systems (Mac) 9 05-14-2001 05:57 AM
C24 Fader Resolution fdc ProControl, Control|24, Command|8 9 03-12-2001 12:53 AM
