Pro Tools 10 constantly crashing
I am in desperate need of help.
My Pro Tools system is crashing constantly. Once I get it working (after about an hour) it's fine until I come to use it again. There isn't an error message it just shuts down and a 'Pro Tools has closed unexpectedly' box appears with loads of code. After this has happened and I try to reopen Pro Tools it refuses to locate my 002 at all. It's then a case of restarting until it changes it's mind and stops crashing. I have upgraded from 10 through to 10.3 and the same issue is occurring. I have have even done 3 full reinstalls of Pro Tools but to no avail. This has been going on too long now. I'm losing the plot. Here's my Mac Spec Model Name: iMac Model Identifier: iMac12,1 Processor Name: Intel Core i5 Processor Speed: 2.7 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 6 MB Memory: 4 GB Boot ROM Version: IM121.0047.B1F SMC Version (system): 1.71f21 Serial Number (system): C02FR2P1DHJN Hardware UUID: 2DDCEC5B-E6A6-5B91-944A-CB326ABF6D88 And I'm using the 002 rack. Please Help!! |
Re: Pro Tools 10 constantly crashing
I'm on 73 crashes in 3 days now.
If it can't be fixed I'll be moving to Logic and selling this set up. Anyone out there who might have a clue? |
Anyone got any ideas? I've just updated plugins and checked all compatibility and still no change.
Hi Scott
Sorry for the problems you have Have your setup ever worked fine? If so:
Personaly I don't think the problem is Pro Tools |
Even if you updated your plugins, I would move everything into the unused plugin folder, and try again.
Then you know for sure that it is not a incompatible plugin. Otherwise I would reinstall the 002r driver.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Scott,
Along with the suggestions about checking for dodgy plugins and checking you have the most up to date drivers for the 002, check that your recording drive(s) are permissions agnostic. This tip cured the incessant crashing on my PT system recently. Look here: http://duc.avid.com/showthread.php?t=327291 Best, John
PT 2021.12 Native 2x Universal Audio Apollo 8p and Apollo 8 Mac Studio. M1 Max. OS Monterey 12.3 Avid S3 and Avid Dock. Dynaudio BM5's. |
Pro Tools constantly crashing while saving | 1176LN | Pro Tools 10 | 51 | 04-17-2014 09:17 AM |
Pro Tools 8 constantly crashing with no errors | theunder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-26-2011 01:18 PM |
Help! Pro Tools is constantly crashing | whirlwind | Pro Tools TDM Systems (Mac) | 3 | 08-04-2005 10:12 PM |
Crashing constantly in 6.9.....Help! | Sty1es | Pro Tools TDM Systems (Mac) | 4 | 06-08-2005 09:47 AM |
HELP ME! 6.0 Crashing Constantly | tactics008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-28-2003 12:00 AM |
