Old 04-29-2013, 06:43 PM
algy algy is offline
Default Timing issue
I am running PT 10.0.1 and have an issue with timing that I don't understand.
When I set up a new session and change the tempo to record at 140 or 145 bpm instead of the standard 120, I always seem to come in at about quarter of a beat late. I follow the click track but for some reason it doesn't quite equate to the beats on the track.
Any idea why? I change the tempo by turning off the conductor and clicking on the tempo in the control strip and manually change it by keyboard.
Thanks
Algy
Old 04-29-2013, 06:47 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Timing issue
Thanks
Algy
What O/S? What interface? What plugins are you using?
Help us Help You - READ THIS Before Posting!
Chris
Help Us Help You
Chris
Pro Tools 2024.10.1
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-29-2013, 07:09 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Hey,
So one thing you need to realize when recording with pro tools is that your buffer setting can make a huge difference when you are playing, in your case its playing back a click track. With a buffer that is set to a longer sample rate you are creating more of a delay.... Most interfaces can be set to use a small enough buffer to not notice the latency (delay time it takes to process the incoming audio to digital/mixing and summing/converting to analog to hear it) if you can lower your buffer as low as you can without having problems (clicks, pops, stopped record or playback) and see if it fixes you issue.
You can also set PT to auto quantize your MIDI to grid (time signature/bpm) if that will help... Let me know if you want to know how to enable and set that.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 04-29-2013, 08:44 PM
cwsand's Avatar
Actually Pro Tools will compensate for the latency caused by the buffer setting, but it could be, like you said, due to monitoring with high buffer settings while playing as it can mess up your timing. You would notice it immediately as it's ridiculous to try to play with your live performance delayed past a certain point - about a 128 buffer setting or higher and you really start to notice it.
Chris
Help Us Help You
Chris
Pro Tools 2024.10.1
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 04-30-2013, 03:21 PM
I will look at the buffer issues and see how I go.
Thanks for the advice.
Automation timing issue WildHoney Pro Tools TDM Systems (Mac) 30 01-20-2017 04:52 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 08:57 AM
midi timing issue corp MIDI 1 04-06-2011 11:39 AM
Issue with setting "Timing" jambirn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2006 09:57 AM
5.3.1 timing issue? da BaSsTaRd! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2002 07:21 AM
